msloan1972 Posted September 19, 2011 Share Posted September 19, 2011 About a week ago, prior to finding this site, and with only a little research, I made this knife. It's not real pretty, but it is functional. I made it from a leaf spring. I heated it to a bright orange, and straightened it. I then used my angle grinder and the stock removal method to grind it to the shape I wanted. I ground and filed the edge, heated it to a bright orange again, and quenched it in used motor oil. Cleaned it up a bit, sharpened it, and wrapped the handle with a double layer of paracord. Then I found this site, and started reading. I didn't temper it. When I hardened it I didn't check it with a magnet. I didn't anneal it properly before I started. BUT, It's holding an edge really well, even after punching holes in a car door I have sitting around. I placed it in my vise and beat the crap out of it with a 3 pound hammer. It flexes, but doesn't bend or break. I intend to abuse the heck out of it and see how it holds up. Picture attached. Quote Link to comment Share on other sites More sharing options...
poundhound Posted September 19, 2011 Share Posted September 19, 2011 pretty good for for first attempt and just using your wits to make it. I am finding that once you learn the proper techniques for creating knifes, you will gain more confidence and create better and better knifes. still not too late to temper it, just remove the cord and heat to 400 degrees for an hour or so a couple of times. PoundHound Quote Link to comment Share on other sites More sharing options...
msloan1972 Posted September 22, 2011 Author Share Posted September 22, 2011 Cool. Thanks Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 22, 2011 Share Posted September 22, 2011 Not at all bad for a first go. Good choice for steel too though there's no guarantee leaf spring is 5160, my guess this is. 5160 can be very forgiving in heat treatment so I'm thinking you lucked out on the steel. Read some from the knife section and talk to the folk. You're already off to a good start but there's nothing like being able to talk to folk who know what they're doing. Oh yeah, Welcome aboard, glad to have ya! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
MattBower Posted September 22, 2011 Share Posted September 22, 2011 Nice job. You did get a bit lucky on the steel, maybe, but still. I concur on tempering at 400ish a couple times. Quote Link to comment Share on other sites More sharing options...
Mtrewyn Posted October 23, 2011 Share Posted October 23, 2011 Very nice, I am thinking about attempting one, in almost the same way. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 24, 2011 Share Posted October 24, 2011 Actually it shouldn't have had that flex if it had hardened properly. I don't know that it needs a tempering if it has that much flex in it! Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted October 25, 2011 Share Posted October 25, 2011 I wouldn't be too hard on it. Keep it and use it and refer back to it as your expertise grows. Great first go...................... Quote Link to comment Share on other sites More sharing options...
