macbruce Posted August 3, 2011 Share Posted August 3, 2011 . Got to fooling around with some 2-1/2'' re bar today for an ''iron in the hat'' piece at RMSC this week end........5'' x 1-1/4 deep....... Quote Link to comment Share on other sites More sharing options...
dkunkler Posted August 3, 2011 Share Posted August 3, 2011 Nice bowl, I like it. What did you squish that with ? Quote Link to comment Share on other sites More sharing options...
macbruce Posted August 3, 2011 Author Share Posted August 3, 2011 Nice bowl, I like it. What did you squish that with ? A 250 PH with flat dies, then I used a hemisphere die made from a mill ball on top with a flat die on the bottom to do the dish... About 2/3 of the way into the first heat I discovered it was galvanized! So I decided to walk to the house and play on the internet for awhile till it burned off....................... ;) Quote Link to comment Share on other sites More sharing options...
Chrispy Posted August 4, 2011 Share Posted August 4, 2011 Good move - no point killing yourself with toxic Galv fumes. Great bowl though - interesting patten created by the Reo. Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted August 4, 2011 Share Posted August 4, 2011 I really like this one Mac. Takes a good eye to see that common material can become something exceptional when moved in the right direction. Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted August 4, 2011 Share Posted August 4, 2011 Very cool Mac. That is definitely a conversation piece. Quote Link to comment Share on other sites More sharing options...
beth Posted August 4, 2011 Share Posted August 4, 2011 thats groovy mac! i really like it :) Quote Link to comment Share on other sites More sharing options...
Frosty Posted August 4, 2011 Share Posted August 4, 2011 Very nice bowl. Good move getting clear of the zinc oxide smoke. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
macbruce Posted August 5, 2011 Author Share Posted August 5, 2011 Anybody else out there ever get something all done and realize it isn't signed? Well, I did it again. That meant I had to get it hot ..........so why not put a bigger hemi die in the hammer while it's heating and widen it while I have it hot anyway.......Could be this is why I ''forget'' to sign things, so I can mess with em just one more time...... ........Anyhow I don't think I did bad, and the finish has a bit more contrast.......... The rebar sure don't look galvanized but it is.......... Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted August 5, 2011 Share Posted August 5, 2011 Like the contrast. Nothing wrong with reheat and rebeat,especially if you have more raw stock. Try throwing the rebar into an acid bath to rid it of the zinc and also give to a bit moire texture next time around. I just know you`re going to do this one again(I saw how much rebar you have left). :D Quote Link to comment Share on other sites More sharing options...
macbruce Posted August 5, 2011 Author Share Posted August 5, 2011 Like the contrast. Nothing wrong with reheat and rebeat,especially if you have more raw stock. Try throwing the rebar into an acid bath to rid it of the zinc and also give to a bit moire texture next time around. I just know you`re going to do this one again(I saw how much rebar you have left). Hydrafloric??.... :unsure: Quote Link to comment Share on other sites More sharing options...
Randy Posted January 19, 2012 Share Posted January 19, 2012 Great bowl! I love the texture. I forget to sign my stuff all the time and have to go back to do it. One thing I've done is to put my touchmark on a plate, in reverse, and when I squish an item on top of that plate I'm signing it at the same time. At least it helps with my pressed pieces. I also made a new shorty touchmark tool. It's only about 1-1/2" long and I welded a light, 1/4" round stock handle to it that's about 9" long. That way I can punch over a large hot piece on the anvil without burning my hand and it works great in the power hammer or press. Quote Link to comment Share on other sites More sharing options...
r smith Posted January 19, 2012 Share Posted January 19, 2012 Hydrafloric??.... Vinegar for a day or two. Works quicker if warm which may help if it is cold in your neighborhood now . I use vinegar to remove galv from the climbing bars on old phone poles to forge them safely. Quote Link to comment Share on other sites More sharing options...
macbruce Posted January 19, 2012 Author Share Posted January 19, 2012 Suggesting hydrafloric acid was my little joke, even if you could get your hands on any I wouldn't want to be in the same zip code as you.......It eats through glass..... :blink: Quote Link to comment Share on other sites More sharing options...
KST1-Derek Fultz Posted January 19, 2012 Share Posted January 19, 2012 And will dissolve your bones if you spill it on yourself. Hydiflouric loves calcium. Not good stuff to mess with on a casual basis. -Derek Oh btw, I love the bowl! What are the final dimensions? Quote Link to comment Share on other sites More sharing options...
r smith Posted January 19, 2012 Share Posted January 19, 2012 :D :D Quote Link to comment Share on other sites More sharing options...
Bibbs Posted February 2, 2012 Share Posted February 2, 2012 love the bowl, at first I would not let myself believe that it was rebar, but after seeing all your pic.s no denieing it, though I have to ask, what gave you that Idea? Quote Link to comment Share on other sites More sharing options...
macbruce Posted February 2, 2012 Author Share Posted February 2, 2012 what gave you that Idea? My avatar kinda sums that up.... ....Lots of junkyard stuff can be forged into cool scuptural shapes eg; chain, threaded rod (I'd love to find some big acme thread) gears, heavy wall pipe....If I can get it hot and get it into the hammer or press I like to see what happens.....Some times it's a diamond, others times it goes in the scrap..... :D Quote Link to comment Share on other sites More sharing options...
