Bird on a branch
This ring will go on a garden arbor that BAM is making to auction at this years conference. Both bird and split work branch are from Mark Aspery's 2nd book. I was pleased with the way it turned out.
post-6008-0-64447300-1296442437_thumb.jp
wow , that is awesome work, you should be proud
That is very nice work. That kind of workmanship is what we should all strive for. With time and practice it can be achieved. You are well on your way to mastering this craft we call blacksmithing.
I really appreciate the kind words.
Thanks guys.
Steve, It's awesome. Did you happen to get any pictures while you were building it? Or is this where I need to "buy the book".
That is the kind of stuff I dream of being able to making
[/q
I didn't take any pictures in progress. There is a pattern for the bird in Mark's book. It is cut out of 3/16 plate. I transfered the pattern to the plate and cut it out with a torch. Then traced out the bird again and filed to the lines. I cut lines in the wing and tale with a creaser I made from a ball peen hammer. I used about a 3/16 hand fuller to texture between the cut lines. A little bit of dishing to the body and head gives it some depth.
The branch was made from 1/2 x 1. You split pieces off to create the smaller twigs. The backside of the foot is welded to the branch. The big end of the branch is riveted to the ring, and one of the small twigs is welded to the ring on the other side.I don't get to spend much time at the forge. I started this project 3 weeks ago, but only have about 5 hours in it. I work pretty slow. A plasma cutter would have saved about an hour and a half, but I used what I have.
Makr Aspery's books are a great resorce. They are easy to understand, very detailed, and well worth the asking price.
Thanks again to everyone for the comments.
Really nice work Steve. Look forward to seeing you and seeing it up close at BAM this year.
I don't get much time at the forge either. I work fast and do have a plasma cutter and still I feel like it takes me forever. Have no worries about the "time it took" thing. I just tell people "you can't rush art". And that my friend IS a fine art piece. Thank you for the picture. Spears.
That looks magic! keep it up.
Thanks for sharing!
Ian
Thanks Phil. Did I hear Ken say you were going to be one of the demonstrators? I'm looking forward to that.
