Glenn Posted December 4, 2006 Share Posted December 4, 2006 Alan, show us your Smokey Joe forge. Most full sized pick up trucks, 3/4 and 1 ton have 13+ inch diameter break drums so they should not be hard to find in your area. Quote Link to comment Share on other sites More sharing options...
Ezra Posted December 4, 2006 Author Share Posted December 4, 2006 Excellent photographic examples, Glenn. Many thanks to the folks that have responded to my inital and follow up questions. It's all the info. I could have hoped for.:D Quote Link to comment Share on other sites More sharing options...
Alan DuBoff Posted December 4, 2006 Share Posted December 4, 2006 Glenn, Mine's a tad different as it's older, but very similar. Mine has a wood handle. I can't remember if mine has the vent in the bottom or not, but that's where I would put the air inlet. (linky pic to spec PDF) Quote Link to comment Share on other sites More sharing options...
Gary Posted December 4, 2006 Share Posted December 4, 2006 My rivet forges are 20" to 22" in diameter. I think anything much larger is a shop forge. I too prefer a hand crank or a great bellows like we use at Ft. Vancouver. I have used electric blowers at a shop where we have the Great Annual Steam-Up here in Oregon and went through much more coal (also burned up a couple of pieces at first). I feel I have more control with hand powered air, and I'm used to it. Quote Link to comment Share on other sites More sharing options...
6013 Posted December 4, 2006 Share Posted December 4, 2006 That is the before photo of the grill, what about an after photo of the Smokey Joe Forge? Quote Link to comment Share on other sites More sharing options...
Alan DuBoff Posted December 4, 2006 Share Posted December 4, 2006 6013, I haven't built one out of it yet, still working on my portable/shop/rivet/whatever forge people want to call it. This is about the size I would like to build a portable solid fuel forge out of though, and a brake drum sounds like it will fit inside nicely. I don't plan to transport my old cast iron forge, I plan to use it mostly at home. This is fairly close in size to a freon tank. I do ponder, would gas not be better for portability...but there's something about using solid fuel I prefer, just like my BBQ. I also have a weber 22 1/2" standard kettle bbq, I've seen folks turn those into forges also. for for portability, the smokey joe has it hands down. Quote Link to comment Share on other sites More sharing options...
easilyconfused Posted December 9, 2006 Share Posted December 9, 2006 Came across this video. I can't tell if its charcoal or coal he has in it but it is a really simple and neat design. Gets the creative juices flowing for those building a forge and makes you look at simpiler instead of getting bogged down in trying to be complex.Video Quote Link to comment Share on other sites More sharing options...
Alan DuBoff Posted December 9, 2006 Share Posted December 9, 2006 Great video, didn't know it was there. This is actually quite an easy forge to build, but it has a welded frame which the mortar cement is packed around. That's Scott Thomas, the smith I study under at Ardenwood Forge. There's a couple pics on my website of that exact forge, Scott was talking about making the frames and selling them and showing people how to make one. If you're interested, contact Scott, there's a link on his website. (linky pic for a few different views) Quote Link to comment Share on other sites More sharing options...
easilyconfused Posted December 9, 2006 Share Posted December 9, 2006 well that's a coincidence I didn't see coming! I thought about it maybe being a smith somebody would know but never thought it might happen. Quote Link to comment Share on other sites More sharing options...
Alan DuBoff Posted December 10, 2006 Share Posted December 10, 2006 I was over at Ardenwood Forge today and told Scott you posted a link to his video. Interesting to understand the forge. It actually similates how an old celtic forge would have been, in the sense that they would dig a tapered trench in the ground, and use rocks as the sheilds. The oval sides similate the rocks, or how they would have forged. There is some speculation on side blower vs. bottom blower. If you look at the pics on my website, you'll see the one of the bottom. There's wire mesh that is wraped around the welded frame, and the mortar is spread over it. The forge is not heavy due to this, and can be picked up by one person. Scott has another one also, I don't have any pics of it. Just turns out that the video had the one I did snap pics of. Quote Link to comment Share on other sites More sharing options...
Scott Thomas Posted December 10, 2006 Share Posted December 10, 2006 Alan, As far as I know, all of the early forges (As well as some today) were all side blast air sources, and that is the way I made my "Celtic" forge. Since we can't dig a proper trench forge at every event, I made a portable "hole in the ground forge" to take with me. It weighs about 70 lbs. and gets up to welding heat very quickly. (Using oak charcoal). Scott Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 10, 2006 Share Posted December 10, 2006 Welcome aboard Scott. It was good seeing you operating your simulated trench forge. I've used trench forges in the past and can relate. Frosty Quote Link to comment Share on other sites More sharing options...
Alan DuBoff Posted December 10, 2006 Share Posted December 10, 2006 As far as I know, all of the early forges (As well as some today) were all side blast air sources, and that is the way I made my "Celtic" forge. Since we can't dig a proper trench forge at every event, I made a portable "hole in the ground forge" to take with me. It weighs about 70 lbs. and gets up to welding heat very quickly. (Using oak charcoal).Scott, Good to see you posting. The design of your forge is really something that may benifit folks, being able to fabricate a similar forge with a little knowledge. How much would you charge someone to build a basic frame? I think folks would be interested in building forges like them. The other forge back behind the smithy was a bottom blower it seemed, with a shield on the backside of the forge. Was that to simulate a different type of celtic forge? Or were you just playing with design? They certainly are functional and can be built easily. As easy as many forges. Quote Link to comment Share on other sites More sharing options...
Ezra Posted December 11, 2006 Author Share Posted December 11, 2006 Portable simulated trench forge...AWSOME! Now, why didn't I think of that? Quote Link to comment Share on other sites More sharing options...
