patrickrock Posted November 15, 2006 Share Posted November 15, 2006 Long timer reader, first time poster.... Hi. Im a new blacksmith, I came to the craft by way of Roy Underhill's wonderful book "The Woodwrights Shop." Took some lessons under the head blacksmith at Conner Prairie here in Indiana and have set up my own very small home forge. Tonight I was trying to forge some counterweighted stocking hooks something like this. Well. I just couldn't get a nice crisp bend on the angles. All I have is an anvil, a hammer, a forge, and tongs/pliers. I am using 1/8" by 3/4" flat stock. I know there has to be a way to do this with the tools I have, I'm just drawing a blank on how to do it. I searched the blueprints and tried to search the forum (does that actually work?) Can anyone point in the right direction? Thanks in advance, Pat Rock Quote Link to comment Share on other sites More sharing options...
dief Posted November 15, 2006 Share Posted November 15, 2006 Hi Pat, You should be able to get a nice bend over the edge of your anvil - unless the edges have been chipped off over time or ground down a tad to far. If this is the case you might try laying a piece of angle iron over the edge of your anvil and making the bend over it. Have fun and keep hammering - it will get easier. Quote Link to comment Share on other sites More sharing options...
patrickrock Posted November 15, 2006 Author Share Posted November 15, 2006 Well. I got a nice curved bend. Just not a really tight bend. It occured to me this morning though that what I should do since its just a piece of thin flat stock is heat it and bend it with pliers. Quote Link to comment Share on other sites More sharing options...
rthibeau Posted November 15, 2006 Share Posted November 15, 2006 If you have a vise, use a piece of angle iron and bend the flat stock over the angle of the iron while being held in the vise. Judicious use of the hammer will get you a real nice 90 degree bend as crisp as you want. If no vise, use a bigger piece of angle iron over the side of the anvil to make up for any rounded edges of the anvil. Or, a 3rd way, use a piece of channel just big enough to fit over the face of the anvil snugly and bend on the edge of the channel. You can also use that channel as a cover for the anvil face to do chisel work to protect the anvil when the chisel cuts through. Quote Link to comment Share on other sites More sharing options...
patrickrock Posted November 15, 2006 Author Share Posted November 15, 2006 The anvil's sides are crisp. No problem there. I think its just my technique. Quote Link to comment Share on other sites More sharing options...
Ed Thomas Posted November 15, 2006 Share Posted November 15, 2006 You are almost certainly NOT getting it hot enough. At the duller orange and red heats, you cannot really forge... all you can do is bend. To forge, heat the steel to at least a very bright orange, and much preferably yellow. At yellow heat, you will have no trouble forging a square corner over the anvil. Quote Link to comment Share on other sites More sharing options...
Swamp Fox Posted November 15, 2006 Share Posted November 15, 2006 If you lack a vise, use two short pieces of angle iron and two sets of vise grips will do the trick. It would appear that you metal is not nearly hot enough before you start your bend. Quote Link to comment Share on other sites More sharing options...
oljoe Posted November 15, 2006 Share Posted November 15, 2006 Hi Pat, One way to make a square corner is to upset the area where the corner is to be. Place it in a vice with the top of the jaws in the middle of the upset area. Fold it over at near welding heat and continue to hammer until you have nearly square at the corner. Remove from the vice and work the other side of the corner over a square side of the anvil. The reason to upset the stock is that, as the corner is made, the hammering will cause the stock to thin. The sides will also need to be dressed up as you go. This should leave the stock the same size throughout. Oljoe Foster Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted November 15, 2006 Share Posted November 15, 2006 Well, pat, this is the method my father taught me during my apprenticeship. Mark the bend and then bend the bar not quite 180° and hammer the bend down being careful not to hammer so much you thin the sides as shown in Fig. A. Open the bend carefully and place across the face of the anvil and hammer down and sideways alternating as shown in Fig. B, being careful not to thin the flat iron. Its quick and easy, but will not give a sharp corner on the outside. Quote Link to comment Share on other sites More sharing options...
Blacksmith Jim Posted November 16, 2006 Share Posted November 16, 2006 When I first read this I was thinking of doing the same thing that Irnsrgn suggested. Seems like a good place to start for easy sharp bends. Quote Link to comment Share on other sites More sharing options...
mtforge Posted November 16, 2006 Share Posted November 16, 2006 There are a lot of good ideas to try, but have you looked at a local blacksmithing group to show them what you're trying to do and get hands on advice? You had said you took classes at Connor Prairie in Indiana. There is a state group there with satellite groups. Iba I'll be at the meeting this Sat near Lafayette (I'm the demonstrator) and would like to see what your doing. Quote Link to comment Share on other sites More sharing options...
patrickrock Posted November 16, 2006 Author Share Posted November 16, 2006 Thanks all for the suggestions, got my bend as I wanted. Most of my problem was not having it hot enough. Although for expediencies sake I made my bend with 2 pairs of pliers, and then cleaned up on the anvil. My stocking holder works great! Even made a not to shabby hay penny scroll on the end. Hard to get it perfectly round without a swage. But patience, many heats, and a soft touch with the hammer prevailed. Thanks again, all, for the suggestions. Quote Link to comment Share on other sites More sharing options...
Site Admin Posted November 16, 2006 Share Posted November 16, 2006 Look at Blueprint BP0184 There are swages available for use, but that are being called something else at the present time. Quote Link to comment Share on other sites More sharing options...
patrickrock Posted November 16, 2006 Author Share Posted November 16, 2006 Excellent idea. Thanks for the link to that blueprint. Does anyone know any scrap yards around Indianapolis. I know there's one in Noblesville, but I can't remember its name. Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 16, 2006 Share Posted November 16, 2006 You may want to try BP0244 There are many things that "can" work, you just need to find what works for you. :) Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 17, 2006 Share Posted November 17, 2006 Is it just me or does this look like an inside radius that could be used for a swage ? Quote Link to comment Share on other sites More sharing options...
patrickrock Posted November 17, 2006 Author Share Posted November 17, 2006 Is it just me or does this look like an inside radius that could be used for a swage ? Hey, I've got one of those! Good eye! Quote Link to comment Share on other sites More sharing options...
patrickrock Posted November 17, 2006 Author Share Posted November 17, 2006 I was about to say the same thing junior did(ohh and with pictures too!). Just fold over and then open it up slowly on the edge of the anvil, even with rounded edges it will give a nice sharp corner. Neat thing to make though, me thinks I should make some for the holidays. yeah. they're the cat's pajamas. pretty neat. Quote Link to comment Share on other sites More sharing options...
