3lbhammer Posted October 30, 2010 Share Posted October 30, 2010 Some of you have kept up with my forge build = click here. My next step is to find a good material for the chimny/ smoke stack. I am looking at culvert material as the fireplace smoke stack material is to small in diameter and to expensive. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 30, 2010 Share Posted October 30, 2010 Some of you have kept up with my forge build = click here. My next step is to find a good material for the chimny/ smoke stack. I am looking at culvert material as the fireplace smoke stack material is to small in diameter and to expensive. Look for old hot water tanks. They have a nice "pipe" in them about 5 feet long. (tip per Jerry Carroll) Quote Link to comment Share on other sites More sharing options...
3lbhammer Posted October 30, 2010 Author Share Posted October 30, 2010 Thanks that is new information to me. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 1, 2010 Share Posted November 1, 2010 I went by the local Habitat for Humanity Re-Store and picked up 2 10" dia 10' long spiral seamed pieces of galvanized ducting for $4 apiece and then later found some SS pieces that I could use for the "at forge" piece for $10. Often the Re-Store wants more than new price for used stuff but enough times I have lucked out that I still check it out regularly. What did the local HVAC place tell you when you asked if they had any appropriate stuff as a tear out? Quote Link to comment Share on other sites More sharing options...
Sweany Posted November 2, 2010 Share Posted November 2, 2010 +1 on the spiral duct. http://www.anvilfire.com/21centbs/forges/low_loss_stack_cap.htm Quote Link to comment Share on other sites More sharing options...
