September 19, 201015 yr hello all, does anyone have a current list of anvil makers/suppliers I am in the market for a new anvil and i have my eye on few, mainly: a euroanvil from blacksmithsupply.com a TFS from blacksmithdepot.com one of the new rhino anvils from www.incandescent-iron.com i would like a 200 lbs or better but these 3 are the only ones i've found and was wondering if there are others i should look at before i make my purchase. I'm also curious what you guys would pic if buying one of these. Thanks a bunch !
September 19, 201015 yr Ozark Pattern 275#+/- only size made cast solid S7 Nimba several sizes available Jim Hoffman makes colonial style from solid H13 80#ish Check the "ANVIL" section in the Forum here for more.
September 19, 201015 yr Author thanks for the suggestion to look around in the forum, I did that a little but dug even further in some posts, and found some reference to fontanini's. these seem more to my liking !! and the price is near what i want to spend and it's made in the USA so there is a plus as well. gonna take a couple days to decide, it's a lot of money to me...
September 19, 201015 yr Fontanini, formerly Rathole Forge makes a beautiful, practical anvil, IIRC, they have two models, about 250 and 450.
September 20, 201015 yr I have used a Euroanvil for a few years now, and love it. It tends to ring a bit, but for the price of a very solid anvil. It is well worth the money.
September 20, 201015 yr Renato Muskovic makes a 400# and 640# south German pattern anvil. I own one of each size. 400# Anvil. I would pm you contact information if you wish. brad
September 20, 201015 yr I have the Ozark pattern anvil by Tom Clark, and I would recommend it, yes it is a big chunk of change but when you forge on one you will know that it was money well spent. The desing of the anvil was well thought out, the feet are upsetting blocks, three pritchel holes, double bick, the list goes on. There is another supplier that I did not see mentioned Reffinghaus anvils, they look sweet lots of different options to chose fromhttp://www.blksmth.com/Refflinghaus_Anvils.htm
September 20, 201015 yr I'm using a Fontanini 250# "Rathole" anvil presently, and it is pretty nice. It is fastened down into a box of sand, has good rebound, and it's not noisy. What I like is that they are cast in the U.S. of alloy steel, and they are carefully sanded/finished by Steve Fontanini in Wyoming. Let's keep some money in the U.S. http://www.turleyforge.com Granddaddy of Blacksmith Schools
September 20, 201015 yr I have the Ozark pattern anvil by Tom Clark, and I would recommend it, yes it is a big chunk of change but when you forge on one you will know that it was money well spent. The desing of the anvil was well thought out, the feet are upsetting blocks, three pritchel holes, double bick, the list goes on. There is another supplier that I did not see mentioned Reffinghaus anvils, they look sweet lots of different options to chose fromhttp://www.blksmth.com/Refflinghaus_Anvils.htm These are also cast of S7 in the USA, in Missouri. Pretty much the in heart of the USA.
September 21, 201015 yr Not sure if this is a request for addresses of current anvil suppliers or looking for recommendations. One current supplier, not US but UK, is www.anvils.co.uk That will take you to the Vaughans website (watch the spelling not Vaughns!) I think they must have the most comprehensive range available ranging from tiny jewellers types upto 250 Kg both single and double horn. Also sawmakers round anvils. They also sell a couple of designs of farriers anvils. Just make sure you are sitting down when you look at the prices. I have a 125 Kg (280 pounder) and think it is wonderful. It would just not be economic to ship one to USA though. That address is worth visiting to see their catalogue. It gives all sorts of ideas for tools which I then go out and make for myself.
September 21, 201015 yr Having just read back a bit I see mention of the Rhinos from www.incandescent-iron.com I have one of each size. I like them a lot and for the price I doubt if they can be beaten. They are very well finished and as hard as a mother in law's heart. Being alloy steel I suspect helps. If you see the prices remember that the company gives a discount if you are an ABANA member. I use the little one as a travelling anvil. I understand that some farriers find them convenient. The big one is great as a striking anvil. I think the point is they are relatively cheap so for the same price you can get a heavier anvil which is usually good news.
September 22, 201015 yr Ozark pattern For me. Went to a BAM meeting sat. and was ask to demo Really missed all the features on my anvil. Big clip on the side is soooo useful. I have had mine for a long time ( first or second ) batch cast, no problems at all and several newbys have hit it pretty hard, Not a mark
September 22, 201015 yr My Colonial Pattern Anvils run 100 pounds and the Continental runs 110 pounds. I had troubles finding the info I had posted on IForge a long time ago about my anvils, so here's a short cut: http://hoffmansforge.com/anvils I am getting prices now for a larger Continental pattern with with a 4" by 4" shelf. 5" wide face, 34" long from tip to tip of each horn. Heat treat facility said no problems getting the 52 Rockwell with H13 that I am using with the other anvils. Estimated weight will be around 300 pounds.
September 22, 201015 yr Jymm Please post here or contact me when the larger anvils are available. As you know I already have one each of your other anvils and both are top notch products. Mike Tanner
