Wesley Chambers Posted September 17, 2010 Share Posted September 17, 2010 An acquaintance was cleaning out a shed on his property and found this sheath, he was going to toss it but I figured I could make something to fit. What I'm wondering is what did it hold to begin with? looks mostly hand made, outer shell looks like conveyor belt, copper rivets made possibly from nails, a plastic buffer with some small cut marks that could have been made from a saw-like blade its the curved shape and small round cutout from the end that confuse me. Edit: its about 20" total length Quote Link to comment Share on other sites More sharing options...
chyancarrek Posted September 17, 2010 Share Posted September 17, 2010 A limb saw and pair of hand shears? Quote Link to comment Share on other sites More sharing options...
Don A Posted September 17, 2010 Share Posted September 17, 2010 I have one similar that was use for a limb saw that fits on a long-stick as used by electric linemen. They have coarse, sharp, aggressive teeth that allow you to cut branches with a fiberglass hot-stick. Not sure what the small pocket would be for though. Don Quote Link to comment Share on other sites More sharing options...
Wesley Chambers Posted September 17, 2010 Author Share Posted September 17, 2010 I was thinking limb saw but the ones I've used are mounted on a shaft not hand held, but I bet your both right, the pocket would hold a thick set of hand shears, any hints on what the hole in the end was for? Quote Link to comment Share on other sites More sharing options...
kcrucible Posted September 17, 2010 Share Posted September 17, 2010 Maybe it was to carry spare blades, not to fit over the tool itself. The notch at the end lets you see if it's "loaded?" Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted September 17, 2010 Share Posted September 17, 2010 My guess is that it`s a sheath for tree service work and it clipped to a climber`s belt by the ring. Many times a climber will need to clear small branches on his way up that don`t warrant hauling up and starting a chainsaw the hand saw and pruning shears are what he`d use in that case. As for the cut out on the end,your guess is as good as mine.It looks like an owner mod rather than a factory cut.As a previous post stated those saw teeth are very sharp and I can`t see why someone would want the end exposed like that.It`d hang on both the rope and the climber on his way up and cause possible damage to both. Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted September 17, 2010 Share Posted September 17, 2010 I would concur with the limbsaw and pruning shears. That was going to be my two cents worth before reading the reply posts. As Bob said, I feel that the knotch at the bottom was not a factory cut. If it was, I think that the stitching would have continued through the curve and if it was to show whether there was a blade in there or not it would (should) have the leather on the backside or body side still there to allow for some protection. Speculations abound. Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 17, 2010 Share Posted September 17, 2010 My guess and that's all it is, is for the limb saw sheath. The cut out in the tip end would probably expose the end of the blade so maybe it's for a lanyard or throwing line? Maybe just make something interesting that fits? Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
LRF Posted September 17, 2010 Share Posted September 17, 2010 Hey Guys, Everyone who said it is for holding a hand saw and pruning shears is correct. I worked as an arborist (tree surgeon) for several years and climbed with a scabbard like this attached to the climbing saddle on most occasions. I have never seen one with a notch cut out of the end. It was most likely done by the owner, not the manufacturer. Bryan Quote Link to comment Share on other sites More sharing options...
tdaleh Posted September 17, 2010 Share Posted September 17, 2010 most tree saws have the teeth on the inside of the curve of the blade so if it was in that sheath you would have the dull top corner exposed by the hole cut out Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 18, 2010 Share Posted September 18, 2010 Lets the sawdust and water out. Ever try cleaning a sheath? Not fun. It is also a good idea to wash tools with a sanatizing solution to prevent the spread of plant disease. I like the folding style tree saws if I am going to climb. I climb for fun not as a job, I hire pro's for more than the hand saw will take. You may be able to make a machete or kukri to fit. Make a card stock template and see what you can get in and out easy. Phil Quote Link to comment Share on other sites More sharing options...
Wesley Chambers Posted September 18, 2010 Author Share Posted September 18, 2010 I was thinking machete, something thick and beefy! Quote Link to comment Share on other sites More sharing options...
