July 20, 201016 yr I need to find some spring steel sheet in .032" thick. I am tiring to repair a spring chair for a friend. I need about a 12" square of material or a strip 2" wide by 3'. Thanks in advance for your help.
July 20, 201016 yr Author would the wide pallet strapping used for very heavy items work for you? If it were 2" and .032" thick
July 20, 201016 yr Author You sometimes find this kind of thing under old beds. I am willing to buy it new I have a budget.
July 20, 201016 yr I am willing to buy it new I have a budget. It may be good practice for forge welding and hammering. It would take a while, but...
July 20, 201016 yr Author It may be good practice for forge welding and hammering. It would take a while, but... I don't need practice I need to get job done and get paid.
July 20, 201016 yr I don't need practice I need to get job done and get paid. If saw steel will work I can give you an e-mail address.The pieces have bluing on them that is easily removed.
July 20, 201016 yr These folks have 2'x 8' 1074 spring steel coils (annealed) available in .032" thickness.A & C Metals
July 20, 201016 yr http://www.uline.com/BL_2904/Strapping-High-Tensile Its .044, and you get a whole bunch for $150. Call around and ask local. Phil
July 21, 201016 yr You can get 1095 in .032 thk. here at Mc Master Carr http://www.mcmaster.com/#spring-tempered-steel-sheets/=81t22g Dick
July 21, 201016 yr Author You can get 1095 in .032 thk. here at Mc Master Carrhttp://www.mcmaster....-sheets/=81t22g Dick thanks that's what I went with
