press idea
I had an idea today for poor man's press, would this work?
a screw type car jack mounted in a frame, with a DC motor hooked to the screw. the DC motor would make it reversable by switching positive and negative wires
would this make a usable press?
something like thispost-13874-061903900 1277523902_thumb.jp sorry for such a rough sketch
It would work, but you would only get 1 or 2 tons of squeeze force.
ok, thats sound like a bad thing the way you say it...
what is the average working tonage for a small press,something the size this would make?
If you've got a decent air compressor, you can cheaply make an air-over-hydraulic mini-press 20T rated...
An air operated 20T jack is 79 bucks at Harbor-freight...
Direct link to the right jack
And here is a link to a thread started by T.A. Toler at Don Fogg's where we discussed about our different revs...
Air operated Mini Presses
Mine is the rusty one at the end of the first page...
http://www.harborfreight.com/garage-shop/shop-presses/20-ton-air-hydraulic-shop-press-with-oil-filter-crusher-65330.html
Are these worth it as a cheap press? Just add dies it looks like.
Phil
This looks to me like the same 20t jack madmike listed, only already in a frame. So IMHO yes it would make a good press
Perhaps a bit loose on the guides if you work off center, but it would be easy to modify, nice find wink.gif
