woodforge Posted June 4, 2010 Share Posted June 4, 2010 Hi all, I have this hand forged antique wolf/bear leg hold trap which the previous owner had heated the leaf springs so they would lose their spring...sorry I don't know the correct termnology for that. Apparentlly he was afraid someone would hurt themselves on it since it has huge teeth on it, but I'd like to restore it to its original condition. Is it possible to put the spring back into the springs? And without removing the springs from the trap? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
John B Posted June 4, 2010 Share Posted June 4, 2010 Hi all, I have this hand forged antique wolf/bear leg hold trap which the previous owner had heated the leaf springs so they would lose their spring...sorry I don't know the correct termnology for that. Apparentlly he was afraid someone would hurt themselves on it since it has huge teeth on it, but I'd like to restore it to its original condition. Is it possible to put the spring back into the springs? And without removing the springs from the trap? Thanks, Mark In theory yes, depends on the size and what you have in the way of heating and quenching it to accommodate it when you are restoring it Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted June 4, 2010 Share Posted June 4, 2010 Hi all, I have this hand forged antique wolf/bear leg hold trap which the previous owner had heated the leaf springs so they would lose their spring...sorry I don't know the correct termnology for that. Apparentlly he was afraid someone would hurt themselves on it since it has huge teeth on it, but I'd like to restore it to its original condition. Is it possible to put the spring back into the springs? And without removing the springs from the trap? Thanks, Mark Unless you plan to put it to it`s intended use I`d leave well enough alone.The trap has been rendered safe. If you re-temper the spring I can almost guarantee some slow head will try and demonstrate how it works and injure either himself or somebody else. Just my $.02 Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted June 5, 2010 Share Posted June 5, 2010 Most states have outlawed toothed traps. Use or possetion is unlawfull. In the same relm as RR equip. Be carefull fixing it. Ken. Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted June 6, 2010 Share Posted June 6, 2010 You must have some dumb neighbors hehe sam ya browsed the internet lateley ?? lotsa stupid out there if someone will set of fireworks in theyre hind end what makes ya think they would be smart about a bear trap?... Quote Link to comment Share on other sites More sharing options...
twcoffey Posted June 13, 2010 Share Posted June 13, 2010 Mark, You don't sound like you are experienced in heat treatment and tempering so don't try to do this without experienced help being present. This is not a beginner's project. You could take the trap to a truck spring repair shop and pay them do the job if they will. Some can be quite contrary about doing work outside their normal routine. You won't get a guarantee I am certain. Ted Quote Link to comment Share on other sites More sharing options...
