Bad Creek Blacksmith Posted May 2, 2010 Share Posted May 2, 2010 Made these bookends for my regerstration peice. The gentlemen that won them is putting them to good use holding up some old bibles that belonged to his father. Cross is made from RR spike,I always wanted to wrap a rose around a cross but didn't want to make another knick knack. I saw some bookends from the Blacksmiths Journal and used some of that plan to incorporate into these bookends. Quote Link to comment Share on other sites More sharing options...
Paul42` Posted May 2, 2010 Share Posted May 2, 2010 Those are beautiful! A lot better than just another knick knack for sure. Quote Link to comment Share on other sites More sharing options...
Tim McCoy Posted May 2, 2010 Share Posted May 2, 2010 Great work - especially like your treatment of the corners on the plates! These really are unique. Do the rose stems just touch the base or are they tenoned through?? Tim Quote Link to comment Share on other sites More sharing options...
Bad Creek Blacksmith Posted May 2, 2010 Author Share Posted May 2, 2010 I was close on time so I drilled the same diameter hole and did a blind weld, not sure if thats the type of weld, but sounds good to me. I did a brown finish using a acid bath, won't do that again to much mess. Thanks for the kind words, put in alot of effort to get this done on time and looking so every thing flowed together. Quote Link to comment Share on other sites More sharing options...
Double Y Posted May 3, 2010 Share Posted May 3, 2010 Nicely done - I think the weld you are talking about is called a plug weld...At least that is what I have heard it called Quote Link to comment Share on other sites More sharing options...
beth Posted May 3, 2010 Share Posted May 3, 2010 i really love them bad creek! they look just right - never seen any like them either. really like how youve done them :) Quote Link to comment Share on other sites More sharing options...
