March 17, 201016 yr I'm curious if anyone has experience with Majectic Forge. Also, how does their craftsmanship and durability compare to Diamondback forges? Thanks in advance for your comments. Mark
March 19, 201016 yr I'm curious if anyone has experience with Majectic Forge. Also, how does their craftsmanship and durability compare to Diamondback forges? Thanks in advance for your comments. Mark I have had my Majestic forge for a couple of weeks and I am very happy with it. It took five minutes to unpack, assemble, and fire up. I do not know anyone with a Diamondback forge.
April 6, 201016 yr Ive got a small diamond back single burner and ive used it anywhere from 30 minutes to six hours strait of forging and its done nothing but heat steel evenly. Well worth the mony IMO.
April 6, 201016 yr Author Thanks for the advice and information guys. I ultimately decided to purchase a Diamondback 2 burner blacksmith model. I ordered it at 11:31 PM last Wednesday and it arrived yesterday. I hooked it up with only one minor gas leak problem around the guage, which was easily resolved with teflon tape. I was up and running quickly. WOW does it heat nicely with no mess and I like being able to roughly adjust temperature by controlling PSI. Mark
October 3, 201015 yr It is nearly a year since the origional post. In helping a thirteen year-old who has a hankering for metal work build a forge, I can use all the information you can provide. Any follow-up would be appreciated.
October 6, 201015 yr I bought a Majestic 2 burner a month ago and fired it up within 15 minutes. It heats very quickly, a RR spike to white hot in about 3-4 minutes with both burners going. Have not had the time to mess with it for serious work yet. I bought it for winter use, outside, I figure I'll put my anvil a few inches in front of it so it captures some heat instead of being air temp when pounding.
October 23, 201015 yr I have had my Majestic forge for about three weeks now. I have used it three times. It was very easy to assemble and get running. It heats fairly quickly. I think that there could have been more attention spent on the welding details of the burner assembly. Overall, if I was buying for the first time again, I would still go with the Majestic. Let me qualify that statement with the disclaimer that I have not seen or had any experience with another of this style gas forge. The Majestic gave me what I wanted within the limited price range I could afford. If I could have pulled another couple hundred dollars, I would have seriously looked at the Chili forge.
October 5, 201213 yr I bought a two-burner back in 2007 on eBay. Worked really well, got very, very hot consistently. The problem was that it warped the sheet steel it was made out of. It didn't ruin the forge or anything, but it was definitely warped away from the firebrick lining. In addition, the hoses provided are rubber...not that big of a deal but something I noticed about the Diamondback's are that all the hoses are copper tubing, which I would much prefer (less chance of crimp, less chance of something hot melting the rubber and causing a problem). That being said, I think Majestic's are pretty darn good for the price, and it appears that the manufacturer is using compressed ceramic blankets in lots of his newer models, in lieu of the delicately-brittle firebricks. Just my two cents.
October 6, 201213 yr I have one myself. 2 burner. With the brick. Same scenario happened to me. I relined it all. They are good for the money. Just needs to have the black iron angled over. Instead of straight up. Gets to hot. And needs a idle circuit too. But That's why they are cheaper than most. Nothing a person Can't redo on their own. If they saw fit to do. Think I'm gonna run copper or probably SS lines. Just cause we use It so much at work. And my pipefitter is better at bending tubing than I. Am. Lol
July 28, 20205 yr Anyone still using one of these and can update on how the do over time? Considering one for my foray into propane forges since they seem to be decently priced, but would love to hear some feedback from someone currently using them.
May 9, 20251 yr Well, I ordered a Majestic 3 burner about 6 weeks ago and have yet to hear a word. Called, emailed, and nothing. So far not impressed with the company.
May 16, 20251 yr Check some of the other posts in this section of the forum. There are a few others who aren't happy about the silent treatment, but I believe there's been some personal hardships that have set the owners back. Some people have had responses, some haven't. I think the general consensus is that they're struggling but still trying to honour all orders. That is only hearsay through the forum though, I don't represent or speak for them in anyway. Cheers, Jono.
