January 13, 201016 yr I took my Say Mak up to its new home, she didnt have a way to unload it so had to drag along the forklift.. 27,700lbs (1,700 over legal and capacity for me) across the scale.... Wouldn't want to have to go very far
January 13, 201016 yr Nice load How much rubber did you leave on the fender/wheel well I'll bet your hitch is starting to look like mine :P
January 13, 201016 yr You are a hammer moving machine! You going for a 6 month record? I still need to move my steam hammer.
January 13, 201016 yr if your goin into the hammer movein buisness you might need to upgrade your truck! get a 1 1/2 or 2 ton!
January 13, 201016 yr As a someone famous say's "GET R DONE". I can't tell from the picture to well. Is your truck a F-350 dually or F-250 single with larger tires?
January 13, 201016 yr Author Its a F-250 with wide tires... And if it wasnt for 110PSI in the air bags it wouldnt be rolling anyplace.. ;)
January 13, 201016 yr Author You are a hammer moving machine! You going for a 6 month record? I still need to move my steam hammer. If you weren't so far away Id love to come help.... I like rigging and moving things... Its almost like building something, a sense of accomplishment to impart your will against an otherwise immovable object :)
January 13, 201016 yr Monster, good looking truck door art. To deliver my machines I use a trailer similar to yours, but I've equipped it with angle iron tracks (that can be extended off the back of the trailer; jack supported) and a rolling hydraulic crane with V-grooved steel wheeels to lift on/lift off the hammers. Toting a forklift is the heavier way to do it. I can by-pass DOT scales and my F-150 pulls it fine. It might carry a Saymak in the bed, but I have a Miller Trailblazer welder there. Your air bags are a dandy way to provide overload support.
January 14, 201016 yr John - could we see a picture of this rolling hydraulic crane? I'm truly fascinated by this idea. Did you buy it or build it? How do you control the pace with which it travels down the tracks (winch?)
January 14, 201016 yr HMMM first it's portable welders, Now its portable power hammers. Larry drive slow and hammer fast. Ken
January 14, 201016 yr 27,700lbs (1,700 over legal and capacity for me) I believe that you were far more than that for the trucks CGVW, probably closer to 10K over. You start getting that far overloaded, and braking can be real fun :o
January 14, 201016 yr Not necessarily - my 2008 F250 is supposed to be able to tow 15K or so. I don't know how old Larry's is, but the GCVW can be quite high - assuming of course the trailer has proper brakes. (Trailers in WA over I think 3000# have to have brakes period.) So it's a legit issue, but at least recent 3/4 ton trucks can have very heavy towing.
January 14, 201016 yr Author Ya, but was his hitch rated for only 10K? They bend a little at 14K I move around some pretty heavy stuff for a 3/4 ton truck but...... My hitch is good for 15K and have a receiver and ball thats good for 14K Because I am licensed as a commercial vehicle and have to stop at the weigh stations all that stuff has to be up to snuff... in this state you pay for weight and 26,000 GVW is the limit without a CDL... so thats what this truck is licensed for and the truck can handle it on short runs... The go is no problem, the turbo diesel has got lots of grunt... I have a good computer brake control system the truck has a electronic "jake brake" exhaust brake which makes for a better than some but still not great stop when its loaded this heavy... You could have a 2 ton truck and pull a 21,000 GVW trailer and still only be able to legally carry 26,000 GVW without a CDL so to me a bigger truck wouldn't do much good.... I might buy a one ton truck next go around but I do installs in this truck and have to get in some tight spots around Seattle... my flatbed trailer I built with a long tongue, 7 foot 6 wide deck and the tires track inline with the truck... Just because the 8foot 6 trailers you can buy are so hard to get in tight spots with... Yeah John... I would really like to see your set up.... I have no plans for going into the hammer moving biz but it sounds slick.... My Dad is really into the Hit and Miss engine scene and has talked about building a monorail hoist trailer like the trucks they use to deliver concrete vaults and septic systems... It sounds to me like your set up might be a step better...
January 14, 201016 yr Author Monster, good looking truck door art. To deliver my machines I use a trailer similar to yours, but I've equipped it with angle iron tracks (that can be extended off the back of the trailer; jack supported) and a rolling hydraulic crane with V-grooved steel wheeels to lift on/lift off the hammers. Toting a forklift is the heavier way to do it. I can by-pass DOT scales and my F-150 pulls it fine. It might carry a Saymak in the bed, but I have a Miller Trailblazer welder there. Your air bags are a dandy way to provide overload support. Thanks John.... I think the door art is a good example of the cost of living in a metro area.. When I bought the truck I talked to several local companys about doing my logo on the door.. The best deal I could come up with around here was $700 for stickers.. a very simple deal that looked pretty plain... I had planed to go to Idaho to my dads shop to build the bed ( he has a real shop with shears and brakes and things ) so I called up Jeff from Jeff's Graphics in Twin Falls who striped and lettered several rigs for me when I lived there.... He hand painted and lettered the truck with a one off design for $400.. That was 4 years ago and it still looks great...
January 14, 201016 yr I move around some pretty heavy stuff for a 3/4 ton truck but...... My hitch is good for 15K and have a receiver and ball thats good for 14K Because I am licensed as a commercial vehicle and have to stop at the weigh stations all that stuff has to be up to snuff... in this state you pay for weight and 26,000 GVW is the limit without a CDL... so thats what this truck is licensed for and the truck can handle it on short runs... The go is no problem, the turbo diesel has got lots of grunt... I have a good computer brake control system the truck has a electronic "jake brake" exhaust brake which makes for a better than some but still not great stop when its loaded this heavy...You could have a 2 ton truck and pull a 21,000 GVW trailer and still only be able to legally carry 26,000 GVW without a CDL so to me a bigger truck wouldn't do much good....I might buy a one ton truck next go around but I do installs in this truck and have to get in some tight spots around Seattle... my flatbed trailer I built with a long tongue, 7 foot 6 wide deck and the tires track inline with the truck... Just because the 8foot 6 trailers you can buy are so hard to get in tight spots with...Yeah John... I would really like to see your set up.... I have no plans for going into the hammer moving biz but it sounds slick.... My Dad is really into the Hit and Miss engine scene and has talked about building a monorail hoist trailer like the trucks they use to deliver concrete vaults and septic systems... It sounds to me like your set up might be a step better... Washington sounds like California on the 26K max GVW without a CDL. I thought about and looked into a CDL but as I'm sure you have noticed, I don't like inviting government into my life unless I have to. Not to mention all the fines and penalties are significantly higher with a CDL. If you do get a 1 ton make sure its not just a beefed up suspicion on a 3/4 ton like the dodge is. They make no improvement on stopping power with the increase in capacity. Your build of the narrow trailer sound good.... Question on the HIT-N-Miss, whats the most HP you have heard off on one?
January 15, 201016 yr CA used to be trailer weight no more than 10K, and a combined weight of no more than 26,000. Otherwise a CDL was needed. The reason I mentioned the weight was that I have a 01 4X4, diesel, 1ton,and the CGVW is 21,300#. The truck curbs around 7,300#, so that leaves a 14K trailer load.I know that I have been well over that with some of the trips I have made, but never ran it across any scales to check. It is easy to overload the new trucks with diesels. Doesn't matter really how much I throw on the trailer, that 5.9 Cummins will get it rolling. Now getting it slowed down on the backside of the Tehachpies, or Halloran Pass can be fun. Looking at an exhaust brake to get more whoa.
January 15, 201016 yr Folks, some of these limits are set by the Feds for all interstate commerce (the whole commerce clause thing), so far as I can tell you need a CDL to drive *commercially* any vehicle over 26,000# anywhere in the US. (And all the other funny rules.) Note that anybody with a regular DL can drive, say, an RV of 30,000 or 40,000 (maybe more?) pounds without a CDL. The 10,000# trailer thing is so confusing I ended up asking the WA state DOT about it, I have some saved email - it makes my head hurt. Of course, any state could have tighter limits as well - so you might need at CDL at some lower number in some states. CA used to be trailer weight no more than 10K, and a combined weight of no more than 26,000. Otherwise a CDL was needed. The reason I mentioned the weight was that I have a 01 4X4, diesel, 1ton,and the CGVW is 21,300#. The truck curbs around 7,300#, so that leaves a 14K trailer load.I know that I have been well over that with some of the trips I have made, but never ran it across any scales to check. It is easy to overload the new trucks with diesels. Doesn't matter really how much I throw on the trailer, that 5.9 Cummins will get it rolling. Now getting it slowed down on the backside of the Tehachpies, or Halloran Pass can be fun. Looking at an exhaust brake to get more whoa.
January 15, 201016 yr Author CA used to be trailer weight no more than 10K, and a combined weight of no more than 26,000. Otherwise a CDL was needed. The reason I mentioned the weight was that I have a 01 4X4, diesel, 1ton,and the CGVW is 21,300#. The truck curbs around 7,300#, so that leaves a 14K trailer load.I know that I have been well over that with some of the trips I have made, but never ran it across any scales to check. It is easy to overload the new trucks with diesels. Doesn't matter really how much I throw on the trailer, that 5.9 Cummins will get it rolling. Now getting it slowed down on the backside of the Tehachpies, or Halloran Pass can be fun. Looking at an exhaust brake to get more whoa. How many HP on a single cylinder or how many HP total? My dad has a 60HP western... I think its a 18 in bore and 16" stroke.... I think you can get up into the 80-100 HP range on one cylinder....
January 15, 201016 yr Larry your dad has quite a collection! The one I sent you was a 150 hp two cylinder, how bout those smoke rings? Maybe you can post it. They also have a three cylinder, 75 hp each.
January 18, 201016 yr At the moment I have the winch off the trailer and it won't be going back on until late February. So I can't get a picture of the set up for a few weeks. The extra screw jacks on the trailer keep it from flopping around as the crane moves. The movement of the crane is controlled by a manual cable winch. The overhead monorail system used for delivering caskets are industry unique, but could be adapted to the hammer and machine tool delivery bizzinezz. Most hammers do not want to be toted in a non-upright position, so that influences monorail height. I think a good toter crane could mimic a forklift. Mine mimics a skid loader. More about this in a few weeks.
January 18, 201016 yr Author At the moment I have the winch off the trailer and it won't be going back on until late February. So I can't get a picture of the set up for a few weeks. The extra screw jacks on the trailer keep it from flopping around as the crane moves. The movement of the crane is controlled by a manual cable winch. The overhead monorail system used for delivering caskets are industry unique, but could be adapted to the hammer and machine tool delivery bizzinezz. Most hammers do not want to be toted in a non-upright position, so that influences monorail height. I think a good toter crane could mimic a forklift. Mine mimics a skid loader. More about this in a few weeks. Great John.... Looking forward to it :)
