todo Posted October 27, 2009 Share Posted October 27, 2009 I have a set of torches and a mig welder. Now need to be able to cut a variety of stock for small projects. Which tool would you recomend to buy first, Harbor freights cheepo band saw, or an $80 metal chop saw that Tractor supply carries?. Thanks for any help Quote Link to comment Share on other sites More sharing options...
chyancarrek Posted October 27, 2009 Share Posted October 27, 2009 For small pieces and quick cuts, I use a thin kerf abrasive wheel in my angle grinder or use a large set of bolt cutters for quick snips on smaller stock. Unfortunately cheapo is cheapo and usually not worth the money in the long haul. Save up for a better quality unit if you can wait. Quote Link to comment Share on other sites More sharing options...
thingmaker3 Posted October 27, 2009 Share Posted October 27, 2009 When cutting 5/8" square mild steel, I can hot cut three pieces for every two my HF bandsaw chews through. For 5/16" square or smaller mild steel, I use a cold chisel. The bandsaw is handy for precise cutting of several pieces simultaneously, such as a bundle of threaded rod. Quote Link to comment Share on other sites More sharing options...
JamesBBrauer Posted October 27, 2009 Share Posted October 27, 2009 I finally broke down and got a Dewalt metal cutoff saw after trashing the gears in the HF version, and never having much success with blade tracking in the HF bandsaw. The cutoff saw gets more use for welding projects than blacksmithing. For instance, I needed to cut a bunch of 3" lengths out of a piece of steel angle last night, and used the cutoff saw. But I was making a bunch of table top clips for some tables, and was able to bend a dogleg in the end of the stock, then cut it with a cold chisel a single heat (with a helper). Quote Link to comment Share on other sites More sharing options...
welder19 Posted October 28, 2009 Share Posted October 28, 2009 Chopsaw, but save for a good one, cheap ones just aren't worth the money. welder19 Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 28, 2009 Share Posted October 28, 2009 Many like the Milwaukee and Makita Porta-bands. Either hand held, clamped in a vise or build or buy a stand.Portable Band Saws - Milwaukee and Porter Cable - Portaband or the cheap HF one:- Harbor Freight Tools - Quality Tools at the Lowest Prices Either way buy the blades at HF Quote Link to comment Share on other sites More sharing options...
pkrankow Posted October 28, 2009 Share Posted October 28, 2009 Are HF blades really comparable to everybody else in this case? Phil Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted October 28, 2009 Share Posted October 28, 2009 If they say LENOX they are:D Quote Link to comment Share on other sites More sharing options...
nc_cooter Posted October 28, 2009 Share Posted October 28, 2009 I have been using the HF hori/vert band saw for over 4 years and for me it's the best bang for a buck. Scrap the stand that comes with the saw and build one from angle. Remove the factory oil from the gear box and replace with a quality oil. Take time to do a complete wheel/ blade alignment. Replace the factory vertical cutting table with one made from 1/4" plate. Use a LENOX bi metal blade and cut some metal. There is a lot of info on the net about these saws and ways to make them better. Quote Link to comment Share on other sites More sharing options...
John B Posted October 28, 2009 Share Posted October 28, 2009 You could also consider using shears or guillotines, they are a much underated tool, and do not require electricity or blade replacements very often. Correct adjustments and they should last you a lifetime, blade sharpening can be done by yourself, and they are very quick, when in use. There are many that are ideal for small size materials up to 2" by 1/2" or 5/8" round or square, larger capacity ones are also available. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted October 28, 2009 Share Posted October 28, 2009 Are HF blades really comparable to everybody else in this case? Phil No, but they are three for $20.00 and sometimes on sale. Quote Link to comment Share on other sites More sharing options...
welder19 Posted October 28, 2009 Share Posted October 28, 2009 I have found MK Morse work the best for me, for pretty much all of my cutting blades and abbrasives, not the cheapest but you get what you pay for.The M.K. Morse Company professional-quality hole saws, saw blades and abrasives welder19 Quote Link to comment Share on other sites More sharing options...
unkle spike Posted October 28, 2009 Share Posted October 28, 2009 I use Olsen brand blades from Tractor Supply, and lately have had great success with the "Super Cut" 10-14 TPI blades from Harbor Freight. And take the time to align the blade according to the book. This is the replacement table I built, it clamps in the vice, and uses one of the bolts that hold the factory supplied table. They are slower than a chop saw, but for me I prefer it over the mess. If I am in a hurry, or it won't fit the saw, I use a cutter wheel in either my 4" or 7" grinder. Quote Link to comment Share on other sites More sharing options...
Tobago Posted October 30, 2009 Share Posted October 30, 2009 I have a Milwauki Porta-Bandsaw and it can't be beat. Excelsior, Ted Quote Link to comment Share on other sites More sharing options...
