DIDTAS Posted October 2, 2009 Share Posted October 2, 2009 Hi guys . thought i would post a pic of a sort of anvil i made up{till i get a real one} the things weight is 160 lb . i used 6x4 solid bar {mild steel} i managed to scrounge 20 feet of the bar. moving it had its problems also cutting. the tire hammer i have just finished has the same bar for the anvil. would it be worth hard facing the thing. DANIEL TASMANIA. Quote Link to comment Share on other sites More sharing options...
orgtwister Posted October 2, 2009 Share Posted October 2, 2009 looks as if you put some thinking and time into the anvil and it turned out well i like it you did a great job Quote Link to comment Share on other sites More sharing options...
MattBower Posted October 2, 2009 Share Posted October 2, 2009 thought i would post a pic of a sort of anvil i made up{till i get a real one} DANIEL TASMANIA. That is a "real one"! Nice work. Hardfacing something that size would be a lot of work; I've done it to a much smaller anvil. I'd try it as-is for a while and see how it goes. It's not like you can't hardface over dings if you decide you want to. Quote Link to comment Share on other sites More sharing options...
arftist Posted October 2, 2009 Share Posted October 2, 2009 Nice Job! Nice Design! You should get some use out of that, even after you find a "real" anvil. From the looks of it, it would be worth hardfacing, except that: Hardfacing rods are rediculously expensive. You can probably buy a decent anvil for what it would cost in rods electricity, labor and grinding consumables. It may be cheaper/better to furnace braze a tool steel top plate onto it. Another possibility would be to find some junk harfacing stick rods (junk because the flux is falling off), wire brush them and use them as tig rods. There are many different properties available in harfacing rods though. Quote Link to comment Share on other sites More sharing options...
matt87 Posted October 2, 2009 Share Posted October 2, 2009 If you take the rest of that 6x4 bar, dig a suitable hole and mount it end-on, you'll have a very efficient anvil... Quote Link to comment Share on other sites More sharing options...
Sweany Posted October 2, 2009 Share Posted October 2, 2009 hardfacing? yes i did mine for about $50.00 it was well worth it. MG55 I belive was the rod. it work hardens, no heat treat after and no butter pass required, great stuff. Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted October 2, 2009 Share Posted October 2, 2009 That looks very real to me. Nice job. Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted October 2, 2009 Share Posted October 2, 2009 if its new metal from a mini mill, just heat it up and using a large stream of water Cool it Quickly using the flood method like they used to harden wrought anvil faces. or just suspend it in a horse tank upside down with a small trolling motor fastened to the side of the tank to move the water over the face. And try an experimental smaller piece first to see if it will harden some. Quote Link to comment Share on other sites More sharing options...
DIDTAS Posted October 3, 2009 Author Share Posted October 3, 2009 Thanks for the kind remarks . will give it a go as is to try it out. have put a bit of the six by four on an one inch thick steel plate for a vertical one as well. will also heat up a bit and try to quench it to see if it hardens. Thanks again . may have a go at hard facing later DANIEL TASMANIA. Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted October 3, 2009 Share Posted October 3, 2009 (edited) don't hard face it, hard facing is too hard and will chip and crack with use and it can only be put on approx 2 passes deep before it pulls away from the parent metal. Use a hard facing UNDERLAY rod which can be put on any thickness without problems, I have repaired many anvils including 4 of my own and I use MG 740 which has a high manganese content, manganese is has anticrushing properties which will stand up to constant hammering, and as welded will be in the 41 rockwell area. it is also forgable and machinable. Jeremy came down to my shop and used it and my tools to repair one of his anvils with MG740 rod, to preheat the face before welding, smoke the top with just an acetylene flame, the preheat just below the face along the sides till the soot dissappears. Your first passes should be around the outside edges. Use a tempile stick and keep the face below 800 degrees while welding, just use stringer beads to lay the weld on, chipping and wire brushing between passes, don't use a wide wash pass as it will impart too much heat in a small area. Edited October 3, 2009 by irnsrgn Quote Link to comment Share on other sites More sharing options...
