Chris P Posted August 28, 2009 Share Posted August 28, 2009 I'm headed to look at a lathe tomorrow and right now I'm kind of walking into it blind. I asked the guy if he knew the manufacture and he said he couldn't recall off hand, but he thinks they were out of New York. This might not be much to go on, but anyone have any ideas who the manufacture could be. Here is a link to the CL ad:lathe, with 3 phase converter At first I thought it was a South Bend, but if its out of NY, then I guess not. Any help would be appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
Dick L. Posted August 28, 2009 Share Posted August 28, 2009 Chris, It resembles a Fitchburg Machine Works lathe pretty close. They were made right here in MA. in Fitchburg. Dick Quote Link to comment Share on other sites More sharing options...
Chris P Posted August 28, 2009 Author Share Posted August 28, 2009 Were they any good? I've been told to kind of steer clear of JET lathes, but I'm not to up on many of the other manufactures. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted August 28, 2009 Share Posted August 28, 2009 I have to tell you that it looks pretty rough from the pics - and I say that primarily because of the rust, which indicates she sat outside in the rain and snow. It may take a lot of work to get it in good shape. Quote Link to comment Share on other sites More sharing options...
Chris P Posted August 29, 2009 Author Share Posted August 29, 2009 I was thinking that. But, I figure it can't hurt to take a closer look. The price isn't too bad, I just have to figure out how I'm going to get it out of my truck if I do get it. Quote Link to comment Share on other sites More sharing options...
dkunkler Posted August 29, 2009 Share Posted August 29, 2009 It looks a little worse than a "slightly used lathe" as the discription says. If all the pieces and parts are there it may be a decent restoration project for 300 bucks. Quote Link to comment Share on other sites More sharing options...
AndrewOC Posted August 29, 2009 Share Posted August 29, 2009 Hi David, this is my favourite lathe site at the moment;lathes.co.uk Tony has useful tips for assessing lathes to buy, 'Buying Advice' as well as details of many manfacturers. also i quote 'For some interesting and amusing advice on checking over a used lathe try: Lathe Milling machine shaper collet parts' definately amusing. enjoy AndrewOC ps i'm picking up a lathe tomorrow as well!!! an Aussie 'Premo' Quote Link to comment Share on other sites More sharing options...
welder19 Posted August 29, 2009 Share Posted August 29, 2009 Tough to tell from the pics but if it is all there and the phase converter works then it is likely well worth the $300, however, I doubt the guy knows how much use it has had or too much at all if he can't even tell you who it was manufactured by. Look for any wear/play in the chuck and shaft, check for wear and trueness of the ways and play/wear in all moving parts in general, look for signs of abuse or misuse, cracks and missing parts, a better quality and more accurate lathe will have V shaped ways. Whenever looking at used machines, lathes or milling machines, take into account any tooling that comes with them, how much and if it's any good, decent tooling (cutting tools) can add up well into the hundreds and even thousands of dollars real quick, I'ev seen machines get sold for less than the amount of tooling they come with. Good luck! welder19 Quote Link to comment Share on other sites More sharing options...
Chris P Posted August 29, 2009 Author Share Posted August 29, 2009 Well, I picked up the lathe for a cool $250 today. Everything seems to be good on it, supposedly it was in the guys garage for 8 years unused and he just recently moved it out side because he needed the room. It was under a tarp when I got there and there doesn't seem to be any excessive wear on the ways. I couldn't start it, but the bearings feel pretty smooth. Nothing stuck or overly rusted, just a bit of surface rust to clean up. Does anyone know anything about W.P. Davis Machine Co.? They were out of Rochester N.Y. if that helps. My wife did a quick google search, but didn't find much but other people looking for info. Doesn't seem to be a well known manufacturer. Quote Link to comment Share on other sites More sharing options...
