Judson Yaggy Posted August 16, 2009 Share Posted August 16, 2009 A post from Grant a while back about fly press tooling got me thinking about this one. Thought some of you folks would like to see this. Made up this bottom tool to go with my ring turning insert for the fly press. Adjustable, bottom pins roll as you slide the workpiece along, a little easier, a little less marring of the stock. I plan on making different shaped bottom tools too, especially one set with a deep groove for bending flat stock the hard way. It clamps onto my big tooling plate that is currently not mounted to the press, but you get the idea. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted August 16, 2009 Share Posted August 16, 2009 Nice! That design will work good but the other design will handle much more force. You could also make rollers with a large flat spot and they would hang correctly by gravity. Good ideas for other tooling. Keep us informed. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 17, 2009 Share Posted August 17, 2009 Neat idea! Quote Link to comment Share on other sites More sharing options...
Dick L. Posted August 17, 2009 Share Posted August 17, 2009 Grant, I'm curious what the advantage of the flat spot is. I understand how they would hang flat side up by gravity but what is the difference flat spot or single line contact in this mount? regards, Dick Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted August 18, 2009 Share Posted August 18, 2009 Dick: A small line of contact will dent the work, see this thread: http://www.iforgeiron.com/forum/f82/no-mar-low-stretch-bending-fixture-12890/ Quote Link to comment Share on other sites More sharing options...
Dick L. Posted August 18, 2009 Share Posted August 18, 2009 Thanks Grant, The reasoning is obvious now! regards, Dick Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted August 18, 2009 Share Posted August 18, 2009 Dick: Yeah, what is not obvious at first glance is that we're not working with thin materials. The force required to bend thick materials often causes deforming if the tooling has insufficient surface. Quote Link to comment Share on other sites More sharing options...
