james_leland Posted August 15, 2009 Share Posted August 15, 2009 I am wondering if its a good idea to turn my now dead propane grill into a forge. I was thinking of laying bricks in the bottom and there is a 3"x3" hole in the center for the air to be pushed threw. Will this work or am I just wasting my time with the thin metal of a mass produced grill?? Quote Link to comment Share on other sites More sharing options...
rokshasa Posted August 15, 2009 Share Posted August 15, 2009 i have seen some vids on u tube, a guy made a fire pot out of a small bbq, he lined it with about 4 or 5 in. of clay. i think it would work but your going to want a better insolation than brick i'm thinking. Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted August 15, 2009 Share Posted August 15, 2009 my portable forge is a BBQ grill make a fire pot out of 1/4" plate if you need plans I can sent you a set. they work great and when you are done working just close the lid Quote Link to comment Share on other sites More sharing options...
james_leland Posted August 15, 2009 Author Share Posted August 15, 2009 thanks guys when I am done with it, I will post the pics. Quote Link to comment Share on other sites More sharing options...
thecelticforge Posted August 15, 2009 Share Posted August 15, 2009 My portable is a brake drum seated on a very thin iron shelf. It seems to be healthy still. Quote Link to comment Share on other sites More sharing options...
Mick Posted August 15, 2009 Share Posted August 15, 2009 Be very careful using common bricks in your forge, clay bricks have a tendency to fracture, spall or even explode when exposed to high temps, especially if a) it contains any moisture there is a considerable temp difference across the brick. Cement bricks are usually worse. I would suggest clay, refactory compound or refactory bricks, plenty of recipes in the archives. Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted August 15, 2009 Share Posted August 15, 2009 I agree with a layer of refractory cement.... thoroughly cured and dried, and then it should be fine. Quote Link to comment Share on other sites More sharing options...
