Double Y Posted May 12, 2009 Share Posted May 12, 2009 I saw an ad for a #2 Common Sense Trip Hammer. They didn't provide any information on the hammer. Do any of you have experience with one? Are they troublesome? Can you find dies? Quote Link to comment Share on other sites More sharing options...
nonjic Posted May 12, 2009 Share Posted May 12, 2009 you might want to have a look at this link for a smidge of info Power Hammer Page - FredlyFX.com Quote Link to comment Share on other sites More sharing options...
Double Y Posted May 13, 2009 Author Share Posted May 13, 2009 Thanks John....I had read that and it is some good info. I guess I should have mentioned I had read that. Just curious if there was additional info. Thanks, JL Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 14, 2009 Share Posted May 14, 2009 Thanks for the link John, good story. I saw another powerhammer about the same color a couple weeks ago. Must be a trend or something. Frosty Quote Link to comment Share on other sites More sharing options...
clinton Posted October 31, 2009 Share Posted October 31, 2009 I have a common sense #2 that I am going to get running soon it is going to be tricky I have seen a couple of the # 1 hammers set up there is a guy here local that has wygers hammer it has the motor mounted above the hammer. Then there is the one that Carl Jennings used with the motor on the side about mid way. Talked to another guy who had one but never got it running he said to use a jackshaft sorta like the guy with the pretty purple one. Any one got one of these that works? Oh there is one more that I know of in south county gotta get ahold of that guy Quote Link to comment Share on other sites More sharing options...
ctp13 Posted November 18, 2009 Share Posted November 18, 2009 I have a common sense #2 that I am going to get running soon it is going to be tricky I have seen a couple of the # 1 hammers set up there is a guy here local that has wygers hammer it has the motor mounted above the hammer. Then there is the one that Carl Jennings used with the motor on the side about mid way. Talked to another guy who had one but never got it running he said to use a jackshaft sorta like the guy with the pretty purple one. Any one got one of these that works? Oh there is one more that I know of in south county gotta get ahold of that guy Hi I have a running Common sense it's not in place but when needed I run power to it . It's a #1 if somebody needs pics or measurments.... I have mine running from a midway motor running up to a jackshaft and down to Hammer. works quite well for it's size. Chuck Quote Link to comment Share on other sites More sharing options...
monstermetal Posted November 18, 2009 Share Posted November 18, 2009 I would guess thats the hammer I have for sale? a 75lb in Seattle? If you had any interest in in I will be going to southern Idaho next week, could get it that far for you. Larry Quote Link to comment Share on other sites More sharing options...
clinton Posted March 1, 2010 Share Posted March 1, 2010 Finally got this hammer running, after much research and some oakie ingenuity (thanks chuck) I got this thing to work and it hits hard, a little sloppy in the slide and the bearings need a rebuild but for occasional use it should be fine for now Thanks to all the guys that helped along the way, Chuck was a great help he came up with this set up and let me come to his place and see it and also use the hammer his is the smaller no 1 hammer and it gets right to work as well. Also I would like to thank dkunkler and mike-hr for their help on checking my math for the pulley size on the jack shaft this stuff is not cheap so it was good to get it right the first time it seems to be running at a controllable speed. I am heading to the scrap yard today to try and find some material to make some more dies and hopefully a piece of cold rolled for the bearing rebuild Quote Link to comment Share on other sites More sharing options...
