New project-Dagger
markb
Did a lot of filing to day.
Flattened it out and profiled, got the basic shape, with the big file. Drilled pin holes. Will start tang taper and blade bevel next.
Edited by markb
I took the idea from a picture of a knife with this basic shape, and then changed small things. I should have made a note of the maker and given credit. I'm not sure when you should give credit for a design, there's so many styles and variations.
It had a guard about 1/8" thick in an oval shape, but I don't know how to do that.
Well I know one way... but skill level is beyond mine.
This could be the subject for another thread.
Thanks for your consideration, I was drawn to the exaggerated profile too.
Heres a spear type profile I never finished.
The rough "grind"- file went real well ,I could keep nice flat bevels and work up to the lie, real crisp, flat and straight. Used the body file(magi-cut) first then the big mill bastard.
Then I went to the small mill bastard and started to draw file. I didn't draw file with the large file.
Drawing with the small file parrallel to the grind lines was too hard to keep the angle and I found out i needed some sort of magnification at this point to see the scratches and lines, had to slow way down. In the prosses I filed a dip in the top flat and there went a nice straight line.
So I think a Opti-visor is in order, the magnifier doesn't allow you to move to see at another angle which is essential.
I filed w/small bastard then sanded w/120 grit one bevel to see how it'd look, may have to go back to file.
I think the dark line in the bevel is a high spot, you can see it from any angle.
Anyway just thought I'd share my learning experience.
Edited by mod07
  • 1 month later...
