Magnesium
Can magnesium plates be used for anything in blacksmithing? thank y’all
Fairbanks model E
IMG_9423.mov Thanks guys! birmingham Alabama. not sure what the issue is with the video. IMG_9424.mov This hammer seems to have to much movement back and forth of the entire rotating assembly. The shaft is located by the belt pully. Could the pully be shimmed to eliminate excessive movement in the shaft. I appreciate y’all’s input!
Fairbanks model E
IMG_9423.mov Rebuilt treadle linkage and it seems to be working well. IMG_9423.mov
Bronze handrail finish
Thank y’all for your replies! it is a private residence so low traffic. central Alabama weather heat, humidity and rain. i think the customer will just let it age naturally
I am building a exterior handrail that will have a molded bronze caprail. is it best to let it patina naturally, clear coat or wax? thank yall
Fairbanks model E
The shop where I work has purchased a Fairbanks model E. we have been working on the treadle linkage. Does anyone know how to adjust brake? thank you!
Iron Mountain Flux joined the community
Flange mount hydraulic cylinder
Happy Thanksgiving I am looking at a h frame press. it has a flange mounted cylinder 10” piston, 2.5” rod. does it need guides to work as a forging press? thank you!
