Freezing Propane Tanks. A Different Solution
Sorry, I should have included a citation to the question which I answered. For the reference, the question was whether it would work to add a second empty tank to the reservoir. The new tank wouldn't add new liquid propane, thus having much effect on the time to freezing.
Does not apply and won't work. The propane is stored as a liquid in the tanks, with propane gas above the liquid surface. When the pressure drops, more liquid evaporates to gas until the tank pressure is restored. If you manifold two tanks together, you will equalise the pressure between them, but that won't transfer liquid propane between the tanks. For manifolds to help against freezing, there needs to be liquid propane in both the tanks. That gives you more surface area to warm up the propane liquid that cools as evaporation takes place.
Less harmful alternative to Kaowool?
It's important to be skeptical and not accept all information from the producers without consideration. But if I have access to two products: One that is known to be carcinogenic and one that is developed to be a less harmful alternative, I would still use the latter given that the price is more or less the same here. I wouldn't work with regular glass wool either without respiratory protection, so having to protect myself does not speak much against Isofrax 1400 for me at least. A package is on it's way to me. Hopefully the performance is on par with Kaowool, or I have done a mistake. Cheers
True. I wouldn't use this without a respirator, but the same goes for regular fiber glass insulation. I should have ended the title of this post with a question mark. Still, I would prefer to use a product that is not (yet?) rated as carcinogenic when the alternative is a product we know is carcinogenic.
Hi In my search for a supplier of Kaowool or similar in Norway, I finally found a supplier of a similar product from another brand. However, after i received an offer for their current product, with clear warnings of the health hazards, the sales person got back to me that they recently got a new product that is less harmful. The product can handle up to 1400C/2552F. From the press release Thought I'd post it here if anyone are interested. http://www.unifrax.eu.com/web/goldminev2.nsf/ByUNID/AA2D17D0F8CA701A80257BB2005055AD?OpenDocument&msg= Note: I am not in any way affiliated with this company. I am in fact about to get quite a bit poorer because of them, since smallest order quantity is one roll... Ouch. Here is the data sheet http://www.unifrax.eu.com/web/goldminev2.nsf/p1_ds.pdf and Safety data sheet: http://www.unifrax.eu.com/web/Audit.nsf/ByUNID/A61BB0ACAF204B89852582200053068F/$File/Unifrax SDS Isofrax 1400 V1.00 (GB-en) 170403.pdf Anyone with experience reading safety data sheets that can comment?
Made a forge and a burner but it’s not getting enough oxygen what do I do
Thanks Frosty. Glad I got it right.
Tock, I recently read through the Forges 101 one and a half time to get my head around how to build a forge. If you haven't done so, I highly recommend it. Rigidizing is done by spritzing a rigidizer on the ceramic insulation blanket after installing it. The rigidizer can for instance be "fumed silica powder" in water and some food coloring for increased visibility. After drying out you use the burner to set it. You'll find more details in the Forges 101 thread. In addition to rigidizing, it is adviced that you line the inside of the forge with refractory. This protects the insulation from damage, makes it last longer, and prevents fibers being dislodged and causing harm to you. Finally, some people use a kiln wash after lining with refractory. This thin layer helps reflect heat back from the walls and heat whatever you are working with. Hope this was clarifying, and if I said something wrong, I'm sure some more experienced members will correct me!
- Planning my first gas forge
Reil Burner Problems!
You might be more right than you realise Frosty. A few days ago he was charged with two counts of possession of an explosive device.
That's a good idea coops1911. Further: I found a suplier of ceramic insulation blanket in china. I don't ask you to vouch for this particular seller or his country, but if anyone had any experience with ordering ceramic insulation from China it would be great to know. http://www.ebay.co.uk/itm/Ceramic-Fiber-Insulation-Blanket-Wool-CeraChem-2600-F-Thermal-Ceramic-Various/182781819854?hash=item2a8ea53bce:m:mnyaG7dK_vSSa0ZCQcPymmw I noticed that the title says 2600F/1426C while the text below says 2400F/1315C. Not too trustworthy, but I have contacted the seller anyway to see if I can get the data sheet.
Thanks, yes I was referring to the doors. Particularly the way you hold them in place. Cast refractory doors wouldn't be much better with regards to being a heat sink, so soft fire bricks might be just as well. Sewer pipes we have. Thanks for the tip Binesman. Bluesman7: Thanks. Sheet metal may be a viable alternative then.
Thanks for the feedback, and I'll be sure to get plenty of pictures. Both of the building and the heat when we get that far. As for door I will certainly try to cast one, but to keep it simple I'll probably go for sliding blocks as in the picture above. So far I have not had any luck in finding an empty helium tank, but I'll keep looking for some time. Irondragon Forge & Clay (what a mouthful), are you happy with that solution? If I'm out of luck: does anyone have experience/know of a build using sheet metal and pop rivets? Welding sheet metal is not an option as I only have access to a stick welder. I'm generally fairly accomplished at making things, but my only experience with welding was 15 years ago Back then I made a rebar and oil drum barbecue while the guests and the lamb were waiting. It wasn't pretty, but no one got hurt.
