So here is where I am at; I have been forging for a few years and a very good friend recently approached me with a proposition. He is an amateur astronomer building his own telescope. He has the mirror cell ground and finished; we are working on a wooden frame to house the entirety of the telescope but the mirror cell presents its own challenge. The mirror cell needs to be mounted in a rather unusual metal bracket. He has persued the option of machining but it would be rather cost prohibitive. He has done some aluminum casting and I am quite familiar with the process and the safety equipment required to perform the task of melting metal. We do intend to make this metal bracket out of brass as he is a tall ship deckhand in his free time and he likes the overall aesthetic. We do intend to melt and cast some of the lesser alloys with this foundry. We have purchased good, reliable safety equipment but were rather fond of the idea of building a home foundry ourselves. We procured, for no cost, a solid #20 propane tank from my gas supplier and, having him bleed it thoroughly, we took it to the shop. After removing the brass valve, filling and draining the tank with soapy water (to remove any excess heavy gas) we cut it in half. Cleaned and dried the tank, sanded down the sharp edges after cutting: we have a usable hunk of metal. We cut a hole for the burner and one for a spill spout, should we have a failure in a crucible. The base of the tank has kaowool and a fire brick to give a very flat surface for the charge. After this lining was installed and a cardboard tube placed to hold the refactory we mixed and poured genuine refactory, rated to 2000 degrees. At this point in the pictures you are probably wondering what is the deal with the yellow cardboard tube, No One had “just the right size.” So, we cut it, punched a few holes and laced it up with some leftover leather to make it work. We finally duct taped a cardboard base on the bottom of the cardboard tube, and along the seams of the lacing. Doing this allowed us to keep our perfectly level fire brick base and have nice smooth foundry walls. We are a little short, as you will see in the photos, and need to mix more to finish filling the rest of the base and the lid. We intend to weld a hinge on it to keep the lid and tank together when loading, unloading, or adding to a charge. I have a few questions and I was hoping you guys could help a bit? I know I can try alloyavenue and I have searched both here and there for these answers but can’t seem to find them, anywhere. Here we go,
1. Once we get this furnace going sitting it on any surface, that surface will act as a heat sink. Will it pay if I weld a few legs on this puppy and get it off the ground?
2. (Rough calculations Ahead) Diameter is about 7.5in and height of the cavity is 8.5in yielding a total whopping volume of 1.625gal. How do I now figure out the diameter of the chimney?
3. Where the spill hole is drilled, does it make sense to weld a little spout on the outside of the tank to guide any molten metal? should the unfortunate event arise.
4. How does it look so far? Please be honest, critical, and patient as I work 2 jobs, one overnights, am getting married in June, and have a 5 year old.
I will I’ll try to respond to everyone ASAP and I hope you have some great feedback for me. The guy who I am doing this project with is one of my oldest friends and my best man at my wedding. That is him in the picture I don’t photograph well.
This picture failed to upload. This is the poured refactory.
