- Natural gas forges
Diamond wheel sharpening
I have a mounted cup wheel now with a resin bonded diamond media. It cuts extremely fine burrs for the shsrpening. 1 to two passes cuts my final edge bevel and leaves a fine hair thin burr. 1 pass on a power strop will leave a razor edge. I have seen a rubber bonded one but can't lose category it. I have seen sources for other media in a diamond bond.
- Diamond wheel sharpening
- Members in Michigan
- Forge blower parts and info
Team. Acquired this blower and refurbishing rite now. 1 week to melt the gook out and rebuilt gear box with new bushings. Super smooth now. Looking for a fan side housing. Someone dodge a hack job welding a bracket and left big hole. Don't really trust the old mounting. Anyone got an extra piece.
Need ventilation advice- lungs hurt
You may be acutely allergic from prolonged exposure to fumes. I would still clean the building as the same spores etc. Get on your clothes which enter the house. I think a move is the best shop option as well. As a chronic and acute allergy sufferer think about seeing an allergist and get a full workup. You may have not yet encounter that thing which could put up into anaphylaxis Good luck
- Steel for hammers
- Steel for hammers
Steel for hammers
Perhaps I should elaborate on the steel in question. Extremely heavy pin used in a commercial truck scale. By mild I should have said suft. In spread easily just driving the pin out of a 12 inch I-beam it's set into. Don't know what it is but mean to see if it will harden before waste time forging anything. How does that sound.
- Steel for hammers
Cardinal. I have had to use a professional HAZMAT group to clean pigeon feces out of an old warehouse that we converted into a boat shop. This stuff can kill. Pressure wash and disinfect. Then shoot with cheapo paint to make sure. Keep the space just make it safe. Great space with good light. Use athe least an N'95 mask or better when u wash. You don't have the build-up I was dealing with so you should be fine to DIY it.
Sounds good. Built my coal/charcoal forge on an old wagon gives us shelf and wheels.
It sounds like a sensitivity to the coup. Get to doctor and then soak the place top to bottom with a bleach mix to help kill mold and bacteria. This stuff can get more acute with prolonged exposure. Chicken coups are nasty places even after years empty. Turbine roof vent also pull a lot of air.
Need a little help here - newbie
Good stuff can be found at scrap grinding yards. They lay aside anything to big or hard to gring. I got a massive 14x30x2.5 inch slab of machined steel at 25 cents a pound. Also bid hydraulic rams. Forklift parts even 400 pound manganese hammer teeth from the shreaders ($1) a pound. Get the yard managers number they are awsome sourses. Mine calls me when he finds items I'm looking for. Scrap is cheap.
