Aman
Everything posted by Aman
  1. This is funny. I did the same thing last night. I made a gas forge a few weeks ago. Never could get it to heat right. Got my kaowool in Saturday and got it put in on Monday. Fired it up last night and heated up a railroad spike. It would get to bright orange as well. Then I went to adjusting on it and now I get to build another burner, because I messed that one up.......oh well better luck next time.
  2. Aman replied to texasalterna's topic in Gas Forges
    Looks great..
  3. Aman replied to Aman's topic in Problem Solving
    I'm waiting on the Kaowool. Then, I am going to get back at it. I have been collecting lots of scrap steel and files and such. Can't wait to hammer away Thanks Aman
  4. Aman replied to Aman's topic in Problem Solving
    After you gave this advice earlier, I measured the chamber and found it to be About 135 cu/in. I then made my burner a 1/2 in burner. I can remove the back door. I also just ordered some Kaewool to insulate it. Any and all advice is recieved Thanks Aman
  5. Looks great. Where are you getting the plans for the tire hammer? Thanks Aman
  6. Aman replied to Aman's topic in Problem Solving
    O.K. I shouldn'y need much. Do you think I need to make the forge bigger? I don't plan on doing big stuff yet. I also plan on building a coal forge sooner or later.
  7. Right now that is real high..... Aman
  8. Aman replied to Aman's topic in Problem Solving
    Thanks guys, I am going to work on it and see what I come up with. I did not know there was a difference in the bricks. Can I get kaowool at most hardware stores? I did adjust the the jet some after taking this picture. Thanks again, Aman
  9. Aman replied to Aman's topic in Problem Solving
    O.K. here is what I have.... I put a railroad spike in it today and after about 8 min. it was alittle red. I also put a mower blade in it and could not get it bright red either. Am I asking to much for this forge or do I not have something adjusted right. After looking at Frosty's flame, I wonder if mine is adjusted right. It has the same blue, but doesn't look like it has the same force. Any advice or comment would be helpful.... Thanks Aman
  10. Aman posted a gallery image in Member Galleries
  11. Aman posted a gallery image in Member Galleries
  12. Aman posted a gallery image in Member Galleries
  13. Aman posted a gallery image in Member Galleries
  14. Aman posted a gallery image in Member Galleries
  15. I know this has been covered, but I can't find where I read it. Can someone help with the instructions on posting pictures. I have my pictures in a folder and clicked on manage attachments, uploaded them, but am not sure how to get them in a post.... Thanks Aman
  16. Thanks. I think I'll try it. I am going to brush it and start hammering away. Aman
  17. OK. It may be tomorrow or Sunday, but I will post pictures. Thanks again, Aman
  18. I was only worried about pitted spots. Wouldn't that show in the iron I am hitting? Thanks, Aman P.S....Frosty, I hope I don't wear you out. I am sure the questions will get more and more as I get into this. Thanks for your responses and thanks to all that have helped thus far.
  19. Aman replied to Aman's topic in Problem Solving
    I used a 3/4 burner. Made it just like the BP0191. It looks lik I have about 134 cu/in. I used a 1 1/2 to 3/4 reducer to make the burner. Should I get a 1 1/4 to 1/2 or can I just step the 3/4 down to 1/2. Thanks, Aman
  20. Will there be a Dec. meeting? I wanted to come to the Nov. meeting, but had other plans set for me. Also, is there any other meetings around the area. I live in Canton. Thanks, Aman
  21. I have two old anvils. One from my dad that he got from my great grand father. It has no horn and is pretty rusted. The other is one my grand father had. It is samller, but has a horn and is rusty. I plan on useing them both. The horned one () is about a 45lb'er and the unhorned one is about a 75 or 100lb'er. Anyway, my question is, what is the best way to get the rust off and have a smooth surface? I have a grinder, but wasn't sure if there was a better way. Thanks, Aman
  22. Aman replied to Aman's topic in Problem Solving
    O.K. I got the forge built. It is a brick forge made using six and a half bricks. Two on bottom, two on top, one on each side, and a half filling the hole in back that can be removed if i need to work with long pieces of stock. I used the BP0191 burner. I used rubber hose and no needle valve. I have a 0-30 high pressure regulator. I am not sure what the fire is supposed to look like. I have played alittle with the regulator. My flame is blue and loud. It hits the opposite wall and rolls both up and down. My next step is to put some stock in it. Just wondering if it all sounds right so far? Thanks Aman
  23. Aman replied to Aman's topic in Problem Solving
    Thanks for all the help. I will be getting an adjustable regulator this weekend. I will try to get the forge put together and get some pictures. I am sure I will many more questions and problems. Still I am excited to be getting into this. I have always been interested in blacksmithing. Again, thanks alot God Bless Aman
  24. Aman posted a topic in Problem Solving
    I am making a gas forge. I have seen several people use small propane tanks. My question is, do you have to use an adjustable regulator or can you control the flame with a needle valve or something like that? Also is it necessary to have a pressure gage? Thanks
  25. Hello all, I am a new kid on the block and am gleaning what I can. The forge looks great so far. I am gathering material to build one as well. For my first one, I am going to build a brick forge for ease and price. It will be propane fueled. Hope to be shaping iron in a week or so. I hope to next build a coal forge, but from what I've read and seen, gas is faster and easier to start off with. Of course there is just something about that coal smell and that fire burning that makes blacksmithing what it is. God Bless
