angiolino
Everything posted by angiolino
  1. hello guys sorry to disturb you, I do not know if this topic is relevant to this area of ​​the forum, however, expose: For personal reasons I should build a hand tool that they use the fire department to clean the areas sogette to fires is a hoe rake I need for my wasteland as they could burst fire could you help me to realize that tools and materials method you advise me to use materials that can be recycled to the blade if I use sheet steel joint venture to use it a little time to dent it and make it unusable I would do a lightweight and sturdy manegevole at the same time, thanks to the next aspect of suggestions I invite you to respond
  2. if you would rather carry a pocket door or sliding doors with a pedestrian gate before to avoid the intrusion of evil-minded? what suggestions could you give me?
  3. Thank you for your informative contribution, I invite other users to participate in and provide me with more information thanks
  4. hello gentlemen users of the forum, today I beg to ask your technical advice because I would like to solve a problem of domestic security. I should build and install an old country house in a security door to prevent access to malentenzionati. Unfortunately, the size of the port are not standard so they are forced to realize it in the traditional way, I need advice drawings or photos, affinche this port does not look like the door of a prison I would like to do it in sections internally and externally by steel plates planks of wood type medieval castle you could give me suggestions on materials hinges bolts locks wood profiles for door and window frames and methods of construction and installation thanks to await the next news https://www.youtube.com/watch?v=ly_BzgHS08E
  5. okay I will let you know next week I begin to use it I have to weld beams 160 mm, I made a good buy? I took basic electrodes of 2.5 mm and 3.5 mm, the welding machine is single phase. the current contract has a power of 3.5 kw, do you think it is sufficient to achieve good soldering resistant? thanks to the next
  6. thanks for the solidarity and the information sorry for the bad English, if some user had more information I invite him to intervene with hello
  7. hello gentlemen users of this prestigious forum, finally for my birthday, I bought a new welder inverter three phase 220 v this is an MMA Welding Machine max. 180 A | PFC SOON Inverter welding with coated electrodes. These models are extremely robust and reliable. Particularly simple to use thanks to features Hot start, Arc force and anti bonding. Weld rutile, basic, stainless and special electrodes. They can also be used for TIG welding with scratch striking. They have to set the DIGITAL DISPLAY, the socket for remote control and VRD function which makes it suitable for working in hazardous environments. think someone has made ​​a good choice among you use it as it is,? that recommendations and opinions you can give me? I await answers thanks excuse my insistence and petulance
  8. prejudice should make a loft for a local high 480 yards, for that purpose by a 180-beam ipe 3 meters long and supported by 2 pillars boxed 80x 80 x 3 mm, I'm creating a portal to support lean spars to which I will have to support the platform, the platform should have a capacity of 400 kg / m / q what can you tell me about what advice can you give me? I will have to use tricks that will not collapse Directory to all and achieve a robust, monolithic mathematical formulas that I have to apply? thanks to those who will want to help me look forward to the next hello tips and experiences
  9. thanks for your valuable advice lighthouse treasure it, for dimensionarte perforated plates fixation cross struts that formula and criteria to use thanks to those who will want to respond
  10. thank you for your testimony I'll think I have advised the above multiprocess say they are like the food processor you use them 10 times and then break them remains without a car is a big investment thanks for your valuable contribution and for your advice if other had more info I invite them to intervene with the next
  11. lathes are 2 one is 2.5 meters long and weighs 2 tons and is all cast iron and the other is 4.5 meters long is a unique fusion of cast iron bench is that the tank that the uprights of the base weight from 3 to 4 tons, I have a simple crane mobile crane classic 60 years old with manual winch and pulley made ​​of beams ua gooseneck you imagine a binda 6 tons and a lot of good will and a lot of elbow grease, if the Egyptians built the pyramids I hope no machinery to move and place these machines as soon as possible in the other thread that's why I wanted to build the gantry crane for use as a crane anyway thanks for your precious words and advice I treasure the next beacon please send illustrative photos thanks
  12. I'm sorry if you expect so much from you attach photos of the machines mentioned translating from Italian to English, the meaning changes a picture is worth a thousand words, however, I had suggested the miller the fronius the Lincon and hobart are not convinced of the esab and saf fo della cea italiana you who have experience and opinion?
  13. hello guys sorry if I am asking for your illustrious opinion. I would buy for my small workshop in a multi-process welding inverter synergic new generation. Of those that are running tig mig mag welding electrode conventional plasma cutting which brand do you recommend? a good efficient and reliable maybe cheap? thanks to those who will take you recommend course of the rising sun but not brands internationally renowned brands prestigious reliable with good performance and fewer defects and certified thanks again
  14. thank you for your intervention and your precious words lighthouse treasure of your experiences commercially sell roller skates what do you think? used hoists for lifting special homemade or other types of dellebinde jack or forklift sorry if I insist but any witness or experience may be useful to me I have to move a lathe 4 meters long heavy 3000kg and other machine I have is a few tools and some do not I will have to buy potendoli build them myself thanks to the infinite patience and your valuable time
  15. thank you for your intervention and your precious words lighthouse treasure of your experiences
  16. guys could someone help me design a box scraper blade to a blade scraper to apply it to a wheeled tractor from someone seventy horsepower means of these tools homemade? thanks for your attention
  17. thanks for the precious treasure words will lighthouse anyway if someone could attach photos and movies of the drawings because when I translate from English to Italian understand correctly, a photo or a drawing worth more than a thousand words thanks for your patience and for your valuable time and your timely testimonies to the next hopefully soon
  18. sorry guys but if you insist in your workshops that lifting equipment used for your loading and unloading material to remove heavy machinery or moving heavy loads for mobile cranes, forklift trucks hoists crowbar farm jack or else could you attach photos and me examples delegate your personal experiences with the next you could attach photos
  19. excuse me if I'm wrong forum, and location is Italian I had to translate since there is no crisis if they produce more industrially so I have to build it arigianalmente that's why I tried your advice, however, I believe that with a beam ipe 180/200 mm can accomplish the horizontal crossbar for the hoist trolley with a large hea H beam 120 can do the pillars pillars, with box-80x 80mm can do the side legs with ipe 180 x 1500 i do sleepers based on which to mount the swivel casters with u 100mm i can make gussett or handkerchiefs stiffening and bracing with iron plate 100mm plates and reinforced bolts 18mm for tIGHTENING what you think someone has gantry cranes for advice thanks for your patience to the next
  20. I have to move the heavy machinery in my workshop lathes drills weight from 1.5 ton to 4 ton commercion not find almost anything I have a hoist and a jack under binda farm machinery takes me round the rollers o tubi pipe what do you think regarding the lever as the build material with which I think 2 meters long is enough what you say based on your personal experience
  21. hello I need some advice to make a gantry crane for my workshop long 3000mm wide 1500mm high 3000mm 2000kg capacity in steel beams with wheels at high flow rate could you help me thanks
  22. hello I need some advice to make a big crowbar maybe with wheels to move heavy machinery like the realization that material I use that measure to adopt thanks roller crowbar
  23. hello my name is angel, I'm Italian ino the welder engineering are happy to be part of your community and to share our professional experiences are bresia london I have a small workshop thanks for the welcome
