IForgeIron Blueprints
Copyright 2002 - 2011 IFORGEIRON, All rights reserved
BP0380 Shop Beverage Holder
by Richard Thibeau
A simple, but very convenient shop accessory which will keep you favorite beverage out of the way while you work, yet readily available when necessary.
The item is made from only two pieces of steel. In this case, ¾” x 1/8” strapping was used, one 11” long, the other 13” long. Almost any size can be used, round or flat or square, as long as the final inside dimensions are greater than the can or bottle you wish to hold.
The basic tools needed are a vise, scrolling pliers, and a jig which is a piece of 3 inch diameter pipe welded to angle iron to be held in the vise.
The first piece of material is marked off for later bending. For a typical can or bottle, the first mark is 3 inches from one end, the second mark is at 6 inches, and the third is at 9.
Place the piece in the vise to the depth of the first mark, bend 90 degrees
Place the piece in the vise to the depth of the second mark, bend 90 degrees. Straighten the piece out so that both bends are actually 90 degrees.
Using the scrolling pliers, bend the second piece around the pipe jig and tack weld the ends together. This bend is done cold depending on the size of the material being used.
The two pieces ready for assembly.
Place the first piece upside down in the vise, slide the second piece over it, use vise grips to hold them in place, and tack weld together. Finish welding and clean up the welds. The piece is now assembled. Rivets could be used instead of welding, there are only two points to connect. Bend the upright of the first piece to fit where you plan to hang it. In this case on the hammer rack which is thin flat stock.
Test the fit. It’s almost completed.
With the appropriate finish applied, it is now completed and ready for use. A proper color will enable you to always find it in a moment.
View full article
