toolish
  1. Here is a video of my trough forge and jumpy castle blower set up. Works well for me and can be made longer when needed. Only drama I find is ash build up after about 3-4 hours of forging
  2. Yeah thanks mate, I was only planning on using it for smaller work at this time anyways so the 10 ton should be ok. Just obtained a motor from a broken dryer so I almost have my parts list checked off now lol Its going to be a long project. Thanks for the input.
  3. how many ton splitter was it? bit worried about it being under powered.
  4. Bit rich for my blood at this stage lol I have the ability to scrounge materials and parts for a very good price. If your not in a rush and keep your ear to the ground you can usually come up with some good stuff. Well good enough for the home use for me anyways. Obviously not the same level that you would want if you were in business doing this type of thing. Half the fun for me is the building, scrounging and reuse of items to make sharp and pointy things lol
  5. Thanks for the input guys, I like the look of that 20 ton one, I am a little worried about the 10 ton being too weak. Been a bit slow on this build, had other knives and projects going. Still collecting bits, To avoid any hose and pump issues I was going to keep the current set up and just try and power the hand pump by a motor. Got an old dryer that I think may do the trick. It's a long work in progress still hunting down parts for a good price ;-)
  6. yeah i was originally looking at doing a powered hydraulic pump. However nothing at the right price has come up at this stage. The hand pumped one comes in around 50 bucks, so the price is right. Little bit worried that I may need 20 ton and the speed of operation. Was hoping motorising the hand pump operation with a fly wheel contraption would help the speed out.
  7. Was looking to make my own hydraulic press. Been looking around and found a few different designs. Been keeping an eye out for what is available. Have locate what I think is a 10 ton hydraulic hand pump ram, which is used to bend damaged car bodies back out and that type of thing. The ram is about 2 foot long. My intention was to use this ram, build a solid frame around it with some thick H beam and make some interchangeable dies for it. Was going to keep it hand operated for a while, then if happy with it, look at driving the hand pump with a motor and flywheel which I would look at making foot pedal operated. Just wondering if there was anything obviously wrong with this concept or any where you guys think i may go wrong with this ram/ pump setup pictured. I was going to use it to help make pattern welded things, smaller hammer and tools, generally will only be used for light work in the garage. Thanks
  8. Yep Im thinking about visiting Park hills currently, they really look fantastic, Very wood grain type of patterns
  9. Wow....Looks like you really went all out on this one. Did you go that far on the layer count for the sake of getting more then one million? The layers look that fine that from the picture it is hard to see that it even has layers. You really do some awesome work on Japanese style blades.
  10. Looks like it is coming along nicely, always wanted to do a peacock, my plan was to use the temper colours for the eyes on the feathers.
  11. Thanks for the advice on the controller, I found some random one off the ebay that said it handled a fair bit of current. Used it for a bit now and find after 10 min of grinding the controller is still cool but the regulator bridge gets a little hot. But still good for now, just think i wont sit there grinding for half hour straight. Had about an hour of use so far and I am happy with it, just got to do the platen thing for flatter grinding.
  12. was thinking about that but the intake on the motor is on the left away from dust with the little fan blowing it out on the right were dust is. thats the hope anyways. still thinking about adding a platen to it. might have to weld up something bendy
  13. Wow it sounds like some of you guys really put it all on the line to get anvils. I like anvils and all and yes I would travel a good distance to get one. BUT if I felt there was a reasonable chance that I was going to get hog tied and mugged I think I would be looking for a different way to find an anvil. Although as VaughnT said anvils seem like an odd thing to run a scam on. Hear a lot of people doing them with boats, as people seem to really like them and will accept odd reasons for a couple of thousand dollars off. Think it is a bit of the old rule: If it seems to good to be true, it usually is. :)
  14. Mines broken but it was the only way I was going to get a 300# (minus a bit) for $160. The lack of hardey hole is annoying however another $50 and I have a leg vice to solve the issue. That one looks good, Id grab it. If you dont want it I am sure another noob will want it
  15. toolish replied to Angus's topic in Knife Making
    was really interested to see the pic of the knife but I get error 404 on my phone and it won't load on pc. was thinking that barb wire normally comes with a gal coating which could cause issues. maybe you could use razor wire, might have more carbon for making sharp things
