striking anvil almost done
This is the striking anvil I am working on. I still need to fill the legs with sand and oil and weld the anvil to the stand. I am debating narrowing the stand plate to the same width as the anvil. P.s this is the first welding I have ever done.post-56432-0-51186500-1412738418_thumb.jpost-56432-0-24541100-1412738446_thumb.jpost-56432-0-73052600-1412738470_thumb.jpost-56432-0-88675300-1412738977_thumb.jpost-56432-0-00848200-1412739023_thumb.jpost-56432-0-69670700-1412739077_thumb.j
I took a Brian Brazeal class a few months ago and he described how they did the hardy holes in the striking anvils we used.
They were 1 inch hardy holes, the steel blocks were about 5x7, 2 inches thick. According to Brian, they drilled the hardies with a 7/8 bit cold, then got the blocks nice and hot in the gas forge (that took a while I'm sure) and drifted them square with a 1 inch square drift, made of some hot work steel. I don't recall the alloy they used, but only having to go a 1/16th wider, you could probably get by with a high carbon drift if you were only doing a single striking anvil.
I did both a 1" & 1¼" hardie holes. I drill the holes ⅛ under size for both and in a coke forge heated the sucker up and drifted with square drifts to size.  Continue driving the drift though the hole as many times as required as the block cools this help keep it to size and not shrink the hole. The plate I used is in the hard end on mild steel 1050 the drifts were regular mild bar. The drifts probably wouldn't survive regular use. The pritchel holes are just drilled in.
Don't forget to brace the bottom legs
Damion you may wish to hold off on welding that beautiful piece down...bedding in caulk of some kind is really the best current method for making an anvil and stand one. I used plastic wrap AND non-stick cooking spray to ensure I was bedding only and not bonding. I've been known to change my mind.
DSW very close on the measurement calculations it's 21 long everything else is spot on. Eddie I drilled and filed my hardy and that took some time I still have some work left on it. Randy may just have to try caulking it , I would rather not weld it if I can avoid it. What kind of caulking would you recommend.
Caulk is defined as "nightmare in a tube" if you get it on you or your clothes.
I've seen posts on the caulk thing and would ask our more experienced what's working out there. If it's allowed to bond how does one get it apart? (heat?). Will plain old caulks or silicone ever harden or do they remain a gooey mess under there for eternity? Like when I change my mind in a few years.
I've always cut it apart. When I have to free counter tops and vanity's that have been caulked down, I'll usually try a thin putty knife and see if I can't jam it between the two surfaces. The long break away utility knives used for wall paper can some times be used to cut thru it if you are careful ( note the blades on these are designed to break, so if you use too much force with the blade extended they WILL break and are very sharp with a high chance you can injure yourself if you aren't careful and are trying to force things)
It takes time but they usually come free without breaking anything.
As far as if they stay gooey, no. Not usually. If the caulk is very thick, it can take quite a while to fully cure, and the center may stay sticky. However the vast majority of standard silicone, latex and urethane caulks completely cure to a flexible material in a few days max, and most cure to workable use in a few hours if not too thick. Some specialized caulks will stay some what sticky over a long period of time. They are a rare exception though and aren't usually found commonly.
I'll agree caulks can be messy. Urethane caulks can be a nightmare as they are solvent based and tend to stick to everything. Silicone caulks are just slightly better and can be a real mess to get off things where you don't want them. Latex caulks aren't all that bad since they clean up with water when still wet.
I had thought about bolting it down but then I would need to either drill holes or fashion brackets to hold it down and they would then be on the face and likely in the way.
Shouldn't be too hard to weld some pieces of heavy angle to the base and anvil and bolt it through.
If you want it easily removable just lay a bead of caulk but put masking tape on the contact surface of the anvil before setting it in the caulk. You'll want the tape wrapped over the edges of the foot or the caulk will sure as sin ooze around the corner and glue it down anyway.
The caulk tends to glue itself to the tape but isn't too hard to unstick.
  • 3 weeks later...
  • 4 weeks later...
