Moveable Post Vice Stand
Hope I posted this in the right place. I've been temporarily using a post vice mounted on a drum. It is time to upgrade and I'm looking for a sturdy and moveable post vice stand design. Any pictures or ideas would be greatly appreciated.
bob
The best moveable post vice stand I've used was medium sized truck rim filled with concrete. The bracket was bolted to a plate on a pole in the middle of the rim. It was portable in that we unbolted the vice and moved the rim and the vice seperately. REAL cumbersome.
Seems like the more portable they are the less stable they are. Some demonstrators I've seen use a tripod kind of affair with a plate they stand on while using the vice. Worked ok for small stuff but heavy bending was tough. Had to have someone stand on one of the other legs.
I use a drill press stand for a table top drill press that I got from sears cut a piece of plate for the top and a piece of 4"x4" with a hole in the side for the leg. works well and if you neef to apply extra force just put your foot on the tube.
16862.attach
I just have it attached with bolts and wing nuts.
my buddy uses a collapsible tripod made out of black iron pipe. its a sweet rig and im looking to make my own. if i get it done any time soon ill drop a pic or 2.
I saw a demonstrator that used the tri-pod from a pipe vise. It seemed to work well.
I fully admit I made mine based on photos others had shared.
I use it whenever I travel and it has really reduced the size of my portable setup.
Tripod Vise - a set on Flickr
the most important part of welding this up is the leg hinges
drill both the hinge holes through the steel for each leg
weld one of them at the proper angle and then bolt the leg and the other piece with a hole to the leg and make sure it's as tight as you want and that the leg can rotate the way you want.
then weld a third spanner piece in to span between the second hinge piece and the main shaft as you can see here S6300296 on Flickr - Photo Sharing!
this and mounting of the chain so that it can't slide up and down takes most of slop out of the tripod stand
-Solvarr
if the drum will hold water put a drain plug on it and fill with water and use as a slack tub and vise stand..drain the water when you want to move it
Unable to do pictures at the moment, but I will try an splain this the best I can. Dad built one during welding class at the local JC. They had a big stack of 24" diameter rounds that are 2" thick. Used one of those for the base. The vertical was a piece of 8" schedule 40 pipe with a 3/4" plate on top. Plate has a hole in case ballast needed to be added later. Rolls pretty easy on concrete when tipped on edge, not so well on outside surfaces. I just moved it the other day by dragging it with the Saturn wagon :D Total weight is somewhere North of 300# total cost was $.10 a pound, welding rod was included in the tuition cost.
OK mine is on a 3/4 inch plate 2X2 it still moves with my fat butt standing on it. Now its wedged up to a 3000lb shear don't move any more. ( thought my butt was more than that) HMMM more beer.
Ken.
I used a front wheel drive rim with a LOT of offset. Welded in a 3" piece of pipe with a plate on it.
Since my vise is a PEG LEG, (broke of with just a 3" stump.), I used a piece of 1" black iron as a prosthetic and welded on a small plate on the bottom to act as a foot, heated up the end and drove it on the stump.
Mounted the vice on the plate and filled the rim with about 100 lbs of concrete.
While it does move around under large amounts of stress, for normal use it is just fine.
