mini-chopper (kevin's #6 and counting)
Greetings All,
I am posting the "almost done" version of this knife.
It is 1095
just over 10" long
2.5 wide
3/16 to 1/8" thick
edge quenched in canola
tempered at 425 for two 3-hour cycles
1095 guard
mokume butt cap
I want to thank those who gave me input when I asked on the "Design and Critique" board.
I am continually pleased by the willingness of those in this community to help someone with essentially no experience. I can't over state how much this means to me.
Any comments, advice, or encouragement are welcomed. You guys have been serving as proxy teachers, although I have a lead from a nice gentleman for some real teaching soon.
Thanks,
Kevin
12125.attach
12126.attach
Yes, it is a beach tree. It is in my front yard here in CT.
I haven't made a sheath yet. I am no good with leather work, yet.
I have been making wooden scabbard by sandwiching a layer of boxwood or balsa with a knife-shaped cut-out between two thin and flat layers of the same wood. Then, I put a small piece of leather in the mouth to press the knife into the wood and act as a "keeper." Then, I grind and stain these. Also drill a hole in end for drain and air movement.
The technique is really simple, and you get a sturdy protective box. Unfortunately, the one's I have made to date have been really ugly. I need to either use a more attractive wood, or get some good leather to cover the final product.
I like working with metal better than wood, so I haven't emphasized this, but I am getting a stack of knives with no covering again, so I will make another run at improving sheath skills soon.
kevin
