February 18, 200917 yr Is there a good rule-of-thumb to judge how oversized a piece should be when hot so it's the right size cold? Say you want 1/2 X 3/8 finished? How much larger should it be hot?
February 18, 200917 yr Steel expands/contracts at a rate of .0000065 inches per inch per degree Fahrenheit. So a 1.0 inch long piece of steel raised 1000 degrees F would measure 1.0065. Sorry if this is more technical than you need. Hopefully someone has a good rule of thumb. Dan
February 19, 200917 yr 1/4 inch per foot shrinkage from liquid---roughly Make that 3/16 from a yellow heat.
February 19, 200917 yr If one calculate on 1832 degrees F the shrink/expantion factor is 1.2 % but on average forging temp which is 1500 F IT IS 1 % And those two numbers are easy to remember Hofi
February 19, 200917 yr Author Thanks all. It's a tiny amount for 1/2" but it means I'm going to have to upset the post vise wedge I just made. Drat!
February 20, 200917 yr Author I wondered if anyone was going to respond to the rather obvious pun! Took five posts before we got one. Incredible discipline :-)
February 21, 200917 yr I was looking around for the expansion coeffecient of steel.. and found any where from .000006 to .000011 per degree F Assuming you could find it at all. There were a lot of tests, BTW how do you use things like the modulus of elasticity or the formaula about bending/ deformation/malleability ( Yeah I know I am kinda a mah/ physics head, besides its fun to spout big numbers during demos... ohhhs and ahhs like iron and steel are that hard)
