February 13, 200917 yr Just finished this today. Yesterday I suddenly got the (peculiar) urge to forge a Machete-like knife. The only steel I had that was big enough was an old leaf spring, so I just used that, even though I greatly prefer using new steel. Since I couldn't be completely sure about the steel I didn't bother spending great amounts of time on it, so after forging it out quite crudely I just ground a rough edge and heat treated it. (2 x normalizing, hardening, and 2x tempering). Gave the edge a quick finish and fixed it up with a shaft of very dense Juniper wood. Any comments and/or constructive criticism appreciated!
February 13, 200917 yr I like it. I think I would have had the blade run all the way into the handle, true full tang style. I think that the design is cool. however I am a bit afraid that if it is a practical machete (chopping brush, and occasionally branches) having the bottom of the blade cut and rounded out may stress the spine a bit too much. I do like the un-polished sides, that always adds to outdoor/hunting/camping knives! Keep it up I hope to see more of your work!
February 13, 200917 yr Very nice! I like it. I like the rounded area above the handle. How thick is it at that point? Hope to see more.
February 13, 200917 yr Author Thank you both very much! I intentionally forged it down so it is a lot thicker where it goes in near the handle, maybe 8-9 mm, as to about 3-4 mm on the rest of the blade. I think it should be solid enough, but I don't think it will get a lot of use anyways. But I definately understand your concern, and I'm glad you made me aware of it.
February 13, 200917 yr Cool knife, Although im concerned it might break near the handle with heavy use which is potentially lethal especially if you have a buddy around you when your chopping. Im not wanting to discourage you, just my 3 cents. Otherwise good work, keep it up:)
February 17, 200917 yr To give it a fair evaluation, how about sending it to me for some intensive testing. If i don't like it I will tell you in about a week, if I do like it then in about 6 months, If I really like it about 6 years. {Big dopey Grin} Very nice
February 20, 200917 yr i reallllllly like the unfinished look, and the handle looks like it wont creat any "hot spots".
