Pressing Hammer Eyes?
Now try this on for size:
I take this 30 ton powered hydraulic press and screw a punch into the end of the ram. The punch is of hot working steel shaped to the inside bore of the hole desired. The nose has a narrow chisel point transitioning into the oval/elliptical punch. There is a stripper plate over the work to strip out the punch. I would use Hofi's magic moly graphite dish soap lube.
How wide should be the cutting edge? Smaller than the hole? By how much? Will 30 tons punch 1 1/2 inch steel? Yellow hot, of course.
Best Wishes,
Warren
That's a 75-80 ton (metric I assume) press, not 10 ton.
A 30 ton might do it though. Speed is a consideration, too slow and it's going to stall and gall.
Frosty
The Hofi press is a 75-80 metric ton hydraulic press "denison" made in England.But he says only 10 ton is needed to drift the eye.
Makes sense, he wouldn't make it work to capacity on a full time basis. Just read the actual pressure off the gage on the face of the press. You can see it in the picture of the machine.
Frosty
