Posted
principal metals does not list 1084 but they list forging temperatures for 1075 and 1095 as follows so I would think that if you kept 1084 within the ranges listed everything would be fine since the forging range is very similar for both steels and 1084 would fall between the two.
1075: Forge at 2200 F down to 1700 F. It is important to do an annealing operation after forging.
1095: Forging may be done at 2150 F down to 1750 F. Before forging the steel should be given a full anneal at 1650 F and slow cool so as to homogenize the alloy prior to forging.
