1045 or Mild steel 4 cone mandrel???
Ok. I have decided to forge me a small cone mandrel to put in the hardie hole of my anvil. I was wondering if I should forge it from some 1045 or just mild steel?
Comments welcome.
Chris
Id use 4140...If it needs holes, once its hardened youll have a bear of a time drilling and tapping, but it can done, and itll be a good rockwell c. The 1045 would work once hardened.
Edited by forging1
defined
Id use 4140...If it needs holes, once its hardened youll have a bear of a time drilling and tapping, but it can done. The 1045 would work but thats a little soft IMO.
Why would it need holes???????
I got no idea, Im just stating it. One thing Ive noticed on this forum is that there are some very creative ppl on this site so I guess Im saying..anything goes er what if!!!;)
i use mild but thats what i had lyin around ....whatever works!
Use mild Chris, you don't actually forge on a cone just true up rings; you can use wood for temporary tooling even.
Then there's the difficulty of forging, the more C the more resistance.
Frosty
I `am going use the 1045, because I got it cut and a handle welded to it . I didnt get to make it today cause the weather. will tommorow though.
Chris
How big are you thinking Chris? What Diameter at the top and bottom, and the height?
It`ll be about 1 1/4" at the base and be around 3 1/2" tall.
Happy HAMMERING Chris. ;)
Frosty
