Posted
I set one of my creaser's(farrier)down next a magnet and left it there
overnite, unintentionally.:( Now the creaser is magnetized. Everything clings to it. I have made several hundred shoes with it and still magnetic. So without having to heat and re-heat treat it, how can i get it demagnetized?
Thanks!
Dan
Posted
You can stop by a TV repair shop and ask f they still have a degauser. (sp?) It only takes a few milliseconds per pulse so they may not charge you anything.
Or you can make an electromagnet and use AC current.
Frosty
Posted
If you do any AC arc welding you can put a few turns of cable around the tool next time you're sticking stuff together.
Hmmm... might even work with a bunch of turns of reg'lar ol' 120 VAC power cord (on something that's running).
Posted
with DC welding machines, if you have the extra leads coiled seperately, when someone is welding, holding something in one coil will magnetize it, holding in the other coil will demagnetize it. FWIW
