wolf mtn Posted December 15, 2008 Share Posted December 15, 2008 I have a post vise with stampings on it, does anyone have any history info on this particular one or this Address? NYCRR 133 ATTORNEY ST. GOLDIE. This one needs a little work. Can anyone tell me how to fix jaws or make a jig for inside jaws to straighten. This one the jaw is starting to seperate on one side. What alterations have you done for your vise? Just curious. Iv'e been sitting on this one debating whether or not to change it. Quote Link to comment Share on other sites More sharing options...
Ted T Posted December 15, 2008 Share Posted December 15, 2008 Here is a URL that may be useful to you. Blacksmith Vises Just for your information in case you are not aware of it. As a rule of thumb you will find that people use the term “Post Vice interchangeably with “Leg Vice”. I mention that so when you do your research it will help broaden you searches to use both terms. Good Luck Ted Throckmorton Quote Link to comment Share on other sites More sharing options...
matt87 Posted December 15, 2008 Share Posted December 15, 2008 Pictures would help. Is the material wrought iron, mild steel or cast iron? Quote Link to comment Share on other sites More sharing options...
D Ravizza Posted December 16, 2008 Share Posted December 16, 2008 I have a small post vise stamped GOLDIE. No other markings though. NYCRR is the New York Central Rail Road. I remember seeing one on Ebay marked as yours is. I would also like to know its history. Please post a picture of it. Dan Quote Link to comment Share on other sites More sharing options...
wolf mtn Posted December 17, 2008 Author Share Posted December 17, 2008 Pictures would help. Is the material wrought iron, mild steel or cast iron? pics coming soon, I am still cleaning it up, friend of mine dug it out of ground behind his garage. Quote Link to comment Share on other sites More sharing options...
wolf mtn Posted December 17, 2008 Author Share Posted December 17, 2008 Here is a URL that may be useful to you. Blacksmith Vises Just for your information in case you are not aware of it. As a rule of thumb you will find that people use the term “Post Vice interchangeably with “Leg Vice”. I mention that so when you do your research it will help broaden you searches to use both terms. Good Luck Ted Throckmorton URL is exceptional, saved for reference. learned alittle on my small vices too. Thanks Again Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted December 17, 2008 Share Posted December 17, 2008 a jig for straightening the jaws is quite simple, first get a piece of half inch barstock......thats it. clamp it in the small side and gently tighten slightly past parallel. if it doesn't move don't force it. that worked on my main forging vice but i had to heat the other one in the forge for it to go straight. Quote Link to comment Share on other sites More sharing options...
