December 1, 200817 yr Finished this set on Sunday. The guy bought 3 sets of matching BBQ tools for x-mas gifts, and finished the third set yesturday. The leafs that I normally do on the handles are kinda like a willow leaf. About 1/2 inch wide, and 3 inches long. Made these shorter, about 1 3/4 inch long and about 1 inch wide. they thinned out real good. The edges are about 1/32 thick. I run some collors with a torch, hit it with a brass brush, and apply linseed while still hot.
December 1, 200817 yr I'm liking the little twists. When I make lid lifters pokers etc, people initially don't get that they don't put their hand through the "eye" of the handle. I don't quite know why they want a knuckle guard on a lid lifter, because I make them perfectly to fit the hand gripping it all the way around
December 1, 200817 yr Author I don't quite know why they want a knuckle guard on a lid lifter, because I make them perfectly to fit the hand gripping it all the way around Same here. I make them to grip the entire handle. These are out of 1/4 square bar, and if you grip it as though it were a gaurd, the tool twists. I do have one handle design for folks with large hands that has a finger loop.
December 1, 200817 yr Insane man, I hope one day to obtain the skills you have dude!! Awsome work!!!!!
December 1, 200817 yr Very attractive. When I make loop handles like that I flatten the material a bit to make a wider and more comfortable grip. Like the handle on pliers. A third item could be a long handled steak knife so you can check doneness without burning your hand. If folk insist on holding them like brass knuckles then perhaps that's how you should make them. Success is being able to give people what they want without compromising your standards. Of course their wants and your standards need to be reasonable. Frosty
December 1, 200817 yr Very nice, I love that finish! Did you hit the entire piece with the brass brush or just the leaves?
December 1, 200817 yr Author Scratch, heavy on the leaves, lightly on the rest. Frosty, When I hand people a tool, the first thing they do is stick their hand TROUGH the loop. Then I tell them to wrap their hand around the whole thing and they say, "That's better." Never tried to flatten em a little, I always round em out to take off the sharp edges. I guess I will have to try that.
December 2, 200817 yr Just curious as to what linseed oil that you are using. The reason that I ask is that boiled linseed oil is toxic because of the dryers that are in it. I did not know this until I received a cast iron wafer iron which had been "seasoned" with boiled linseed oil. I liked the color and finish but upon further inquiry, I found out that it was toxic and should not be used on any cooking utensils. Jerry
December 2, 200817 yr Sam, I hope that your not eating your cricket bats! Boiled linseed is only toxic if ingested and I don't think your going to get that much off of the end of a fork.
December 2, 200817 yr Author I don't even put it on the business end. I clamp them upright in my leg vise, run the colors, brush on the oil, then wipe off the excess. None is put on the fork or hook. I have prolly sold about 50 of these thing and have not lost a customer yet.
