Forging a seahorse
I know I'm not the first, but I did a search and couldn't find a WIP on how to forge these here, so I thought I'd share my process for any newer smiths (don't forget there are many different ways to forge stuff).   I consider this a intermediate/beginner forging activity.  Nothing other than hammer, anvil, and 3 top tools needed for this part.
The starting stock for this example was 1/4" x 1-1/4" flat bar
First heat - Draw a taper over the horn (in this case it's ~4"):step1.jpg.c17f225b839bd8ff95ad83556490a1ce.jpg
Second heat - isolate material for the belly over the near edge of the anvilstep2.jpg.4ec9340fc7eaf54615869a4644e49f39.jpg
3rd heat - start isolating head and lips over the tip of the horn on other side of barstep3.jpg.709b9bd3c3199fc74f91484992b433f2.jpg
4th heat - clean up the mouth using SOR methodstep4.jpg.aaad436e981718f03d06cdac4c71dff7.jpghere's a close-up pic, one time we actually encourage 'fish-lippingstep4detail.jpg.d958bcd8651e0dce0b66435bacb8b7d9.jpg
5th heat - begin fullering a line down the back to isolate material for the dorsal spikes and fin using a 1/16" dia. fullering tool.step5.jpg.11c5c4abe56306a0ed7a34192a789283.jpg
Take as many heats as necessary to go from near the tip of the tail to the top or the headstep5a.jpg.9ae4194f76f4217c3439fedfe3c5ba65.jpgstep5b.jpg.8ea3d22a9c2ee2e9e0ec577cfdc890f4.jpg
Next, widen the fuller and clean up using a 1/8"- 3/16" fullerstep6.jpg.6c663dd431d13594f89cf2c1e9b79458.jpg
Next, isolate/mark out segments using a butchering tool and round out the tip of tailstep7.jpg.548642ce27c9beea5fc35cdc001dd293.jpgstep8.jpg.6ea2fcc03309871e322e276518a0d6dd.jpg
Next, use butchering tool to knock down the corners to give the body depthstep9.jpg.eb8a97b257c0064c398eafbf4b4cee05.jpg
Next, start separating the spines using a flat hot cut chisel with square sides. . .step10.jpg.369f468ec74a8ddc507ba923e42ae0c6.jpg . . .skipping a few segments for the dorsal finstep10a.jpg.911ec610c09215c44a2e2cbdef6e1a03.jpg
Next, fuller out the dorsal finstep11.jpg.ac53b3f77b4e9a18c46a0cbb0452327e.jpg
Finish shaping the dorsal finstep12.jpg.d49d2ff070bddb82a78c92d522ddf48e.jpg
And then finish the seahorse by first curling the tail (I have better success when I start by heating the thicker part of the tail and starting the curl there first, then working on the tip to curl in opposed to just doing the whole spiral starting from the tip) and then heating the neck to bend the head into the proper positionstep13.thumb.jpg.e9d3c5b4a64221c86d7c332902f6d0ec.jpg
Finish up however you want, I'm probably going to punch/drill holes and then use rivets for the eyes if they are going on a project using traditional joinery, or I use button head allen head screws for other applications.
Thanks for looking and I hope someone finds something useful in this.
Thank you BillyO, that is a most excellent WIP.
Having done a quick search for seahorse images, there is LOTS of room for the imagination to modify your basic process. What a great place to start.
Again thanks.
thanks BillyO. Very clear pictures and explanation.
On 8/3/2025 at 1:09 PM, bluerooster said:
Awsome!  Something else for me to try. :D
Please share pics when you do...
