its pommelness
ross_lad
Welding will usually mess up the temper of the tang if it's the same steel as the sword.
dablacksmith are you using low temp silver solder (only 2-5% silver) or high temp silver solder closer to 90% silver depending on type, (old british silver coins can be used for medium hard solder in a pinch)
I tend to try to fit the guard on and sometimes will heat shrink it in place.
ime useing low temp silver soder so it dont screw up the temper
