First Attempt JABOD
I started with some leftover wood from a previous project. Initially, I was using clay from my pond, but it had a lot of rocks, and from my digging on this forum, rocks are not ideal.
Where the tuyere enters the box there are firebricks which I then covered with dirt, firebricks are also on the bottom which are pictured.  One broke so I tried to situate it against the tuyere and they can be moved as needed.
Looking for any feedback, there are a lot of posts on here, and everyone does the JABOD with their flavor, depending on the use case, materials, experience, etc.  I am still looking to source a hairdryer or some air-moving device so not yet ready to fire up, but wanted any feedback as I go on this journey.
Thanks
From what i see it looks like the tuyere needs moved back. The end will burn off if it is in the fire. When i did mine i put the tuyere in about like that, formed the dirt/clay around it, then slid it back so the last inch or so was a clay tunnel.
What Billy said. My first JABOD used a very thin-walled pipe that burned to a crisp in the first couple of firings. A heavy pipe (3/4”-1” schedule 40 black pipe or heavier) completely encased in the dirt fill is the way to go.
Awesome thanks guys, I moved it back as suggested, the pipe I am using is a 3/4" sch 40 black gas pipe.
