Archie Otteson Posted February 25 Share Posted February 25 I recently came into possession of a chrome plated Hydraulic cylinder rod. It is 2" diameter and 8 feet long. All chrome is intact, and one end has the eye other end is threaded. Do you know what the steel might? Not really sure what to do with it. Looking for ideas. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted February 25 Share Posted February 25 I think the chrome plating makes it kind of problematic for forging no matter what kind of steel it is since heating it to forging temperature will cause all kinds of dangerous heavy metal inhalant issues. You can remove the chrome with acid but then you have the problem of disposing of toxic metal contaminated acid and residue. Maybe bury the treaded end 6' into the ground to make a chrome plated hitching post? "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Archie Otteson Posted February 25 Author Share Posted February 25 I don't have anything that needs hitching except the dogs. Wifey or kids won't hold still long enough. (That's a joke) Maybe a decorative fence in front yard? Part of a "ratrod" project? Sounds like welding is an issue too. Perhaps burning the chrome off in a firepit? or grinding? I know it's a stretch, It's a beautiful shinny chunk of steel. I hate to just let it go. Well, anyways it'll get moved to the back yard for now. Quote Link to comment Share on other sites More sharing options...
gewoon ik Posted February 25 Share Posted February 25 For welding you can grind the chrome away locally to the steel underneed and weld on it. Putting the rod in a campfire is like putting it in a forge. A lot of nasty chrome that you will inhale. A hydraulic shop mostly can or know a place where they rechrome those things. And those people can take it off. You can also use it as an anvil. I use a pen as an anvil Quote Link to comment Share on other sites More sharing options...
BillyBones Posted February 26 Share Posted February 26 Contact a local plating company and see how much it would cost to get the chrome removed. If they can put it on they can take it off. Also it may be a lot cheaper than you think. Regardless a phone call to ask is free. I have burned paint off in a bon fire but i would never think of doing chrome plating, or even zinc for that matter. Quote Link to comment Share on other sites More sharing options...
