raypa Posted October 2, 2008 Share Posted October 2, 2008 A guy I work with tinkers with a store bought gas forge and it peaked my interest. I have seen the gas 10" pipe blue prints on here and deceided I would try to make one and get into the hobby. I have looked around for the kaowool to line the pipe, but I'm only finding 1/2" thick matierial. Any suggestions on where to shop? Also, would I be able to use a larger diameter pipe? 10" seams small once you get your insulation in. Any additional advice is more than welcome Thanks! Quote Link to comment Share on other sites More sharing options...
jimbob Posted October 2, 2008 Share Posted October 2, 2008 go to anvilfire look under plans he has a link there Quote Link to comment Share on other sites More sharing options...
me miller Posted October 2, 2008 Share Posted October 2, 2008 www.elliscustomknifeworks.com Quote Link to comment Share on other sites More sharing options...
keykeeper Posted October 2, 2008 Share Posted October 2, 2008 C. J. Products Inc. Attn: Jay Hayes 100 Christmas Place, Weston, WV 26452 (304) 269-6111 email: jay@hrea.coop "Everything needed to build Gas Forges; Ceramic Fiber Refractory Blanket & Board by the foot; ITC-100, Super Duty Floor Bricks; Industrial LP Gas Regulators, Hoses, Valves, and Fittings; High Performance Burner Kits, Valve Manifold Kits; Machined Burner Nozzles & Orifices; LP Gas Forge Kits in many styles and sizes to fit your needs and budget including our new Super Wide Oval Forges and Clamshell Forges. Custom sizes available, Technical Support"This is from an internet classified ad, I copied the material over to here for you. I know Jay from our state blacksmithing organization, very nice fellow, very good to deal with and highly knowledgeable about forges. Shoot him an email or give him a call and he can probably help you in short order. Quote Link to comment Share on other sites More sharing options...
NateDJ Posted October 3, 2008 Share Posted October 3, 2008 Also, would I be able to use a larger diameter pipe? 10" seams small once you get your insulation in. In my first forge I thought the same thing and found I needed to add some firebrick to decrease the inside area or add a 2nd burner to increase the heat in order to get it to heat up enough to forge with. There are calculations that will help you get an idea of how much space you can heat with each type of burner. Perhaps I should have used one of them LOL! Quote Link to comment Share on other sites More sharing options...
covforge Posted October 3, 2008 Share Posted October 3, 2008 raypa, Let us see where you are and someone close may can help you. I have several large pieces of cerwool myself. Travis Quote Link to comment Share on other sites More sharing options...
raypa Posted October 8, 2008 Author Share Posted October 8, 2008 I'm in Jeannette, PA which is aboout .5hr from Pittsburgh. I'll update my info. Thanks for all the help!! Ray Quote Link to comment Share on other sites More sharing options...
ChrisB Posted October 8, 2008 Share Posted October 8, 2008 Zoeller Forge Gas Forge parts Quote Link to comment Share on other sites More sharing options...
covforge Posted October 8, 2008 Share Posted October 8, 2008 Ray, I beleive there is a co. called Northstate Boiller they should have anything you need. I know ther is at least one or tw0 boiller co's in your area. Travis Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted October 9, 2008 Share Posted October 9, 2008 Hey Nate, I like the name!! Quote Link to comment Share on other sites More sharing options...
MRobb Posted October 9, 2008 Share Posted October 9, 2008 Try two layers of Kaowool. Then maybe some ITC100 on top of that. Quote Link to comment Share on other sites More sharing options...
raypa Posted October 9, 2008 Author Share Posted October 9, 2008 Thanks for all the help. I will check all the resources.... If work lets up to give me some time. Thanks again, ray Quote Link to comment Share on other sites More sharing options...
