Pipe Tomahawk
I just finished up a pipe tomahawk today. I forged it out of a peice of 1inch Dom pipe with ¼inch walls, slit it down the middle and forge welded a 1080 bit. The handle is charred hickory with a damascus smoke plug. I put a sliver of leather between the bowl and the handle to create a better seal.
Nice. Thanks for sharing your work.
  • 1 month later...
Great job, I've wondered what was the best way to make one and you sure made it look easy.
Thank you! It wasn't as difficult as I first thought. The big thing is to make sure you don't remove too much material when splitting the pipe so use a thin bandsaw blade. My next one will have a wider blade. I think i took off a little too much this time. But it'll be easier when I get a big metal musher lol.
