October 6, 20232 yr Someone is advertising what they call a "welding safety apron" in the local FB Marketplace; it's basically a heavy leather apron with a quilted fabric lining, with a slit and leg straps like a farrier's apron. The interesting thing is that most of it is covered with heavy metal staples that go all the way through. Anyone seen anything like this before? I imagine it would be good for industrial shops where there's a high chance of getting cut, but I suspect the staples might not be great for keeping the heat from a forge at bay.
October 6, 20232 yr I suspect that it would be used by a meat cutter or butcher to defend against accidental cuts, similar to mail gloves, sleeves, or aprons. I suspect that it would be inferior to a regualr leather apron for blacksmithing because of the weight and lower insulation. I'd pass even if it was free. GNM
October 6, 20232 yr Author I see what you mean, but the absence of bloodstains might argue against butchery.
October 7, 20232 yr Might be good if you sharpened a lot of knives or did a lot of wire wheel work. It'd probably be just the thing if your shop gremlins come at you with little simitars but I think it's specialty PPE for other than blacksmithing or hot shop work. Looks cool though, maybe a Halloween costume? Frosty The Lucky.
