Max1775 Posted December 2, 2022 Share Posted December 2, 2022 Been testing different things over the last year and finally have my forge configured the way I like it. Has a good running burner, decent floor, adjustable door bricks, and is comfortable to use for what I do. Ordered some 100HT to coat all the different removable pieces and redo the inside for max efficiency. Feeling confident, I took my time getting any loose stuff off, blowing out all the dust, and mixing the wash to a fantastic consistency. Got the workshop to 70 degrees, coated everything with a thin consistent layer, and commenced operation clean-up… Then it hits me. I didn’t dampen anything before I applied the coating. I feel like Barney Fife right now. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 2, 2022 Share Posted December 2, 2022 Hey, I identify with Barney! The trick is to carry a gun that only needs ONE bullet to do the job. I would've recommended something other than ITC-100 as your kiln wash. Assuming that's the product you mean when you say 100HT. I don't recall seeing you post for a while, what you been up to? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Max1775 Posted December 3, 2022 Author Share Posted December 3, 2022 1 hour ago, Frosty said: Hey, I identify with Barney! The trick is to carry a gun that only needs ONE bullet to do the job. I would've recommended something other than ITC-100 as your kiln wash. Assuming that's the product you mean when you say 100HT. I don't recall seeing you post for a while, what you been up to? Frosty The Lucky. Yes sir, it’s ITC-100. The first time I used the Plistix that came with the forge and it didn’t hold up all that well. However , I think I put it on too thick. Frosty, what would you recommend? Lol, as for my absence, my job has been consuming. I finally took a different role that has allowed some normality back in life and time for things other than chasing dollars… Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 3, 2022 Share Posted December 3, 2022 Ayup, too thick did it. Mix it the consistency of thick-ish latex paint, butter what you're applying it to and brush it on thin, coat of latex paint, thin. Let it dry thoroughly between coats and always butter before applying the next coat. An incandescent light bulb in the forge will speed drying just don't get carried away, 40w is probably plenty. Ah, the JOB. Mine always got in the way of what I'd planned on doing and it only took me about 20 years to stop planning things. Then I transferred, stopped living in a tent most of the time and after a while started making plans again. Then I got married and now my plans are made for me. That was a win win. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Max1775 Posted December 3, 2022 Author Share Posted December 3, 2022 (edited) Next time around I’ll try the Plistix again and put it on thin. Lol, hopefully this will work for a bit or that will be sooner than later. Appreciate the advice! Edited December 3, 2022 by Mod30 Remove excessive quote. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 3, 2022 Share Posted December 3, 2022 You're welcome, it's my pleasure. Plistex is really tough effective stuff done right, it'll last quite a while. No need to quote when you reply to someone, especially when it's the post above. If you're trying to pick someone out in a thread full of IFI yahoos a name works nicely. Quotes are usually for picking out a point from a long post you wish to address or a really old post, say something Bender squeeze harder showed last year. The mods will probably delete the above quote and drop you a note. It's no biggy, just part of the learning curve. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Max1775 Posted December 3, 2022 Author Share Posted December 3, 2022 Appreciate the info again sir! Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 5, 2022 Share Posted December 5, 2022 You're welcome, it's my genuine pleasure to pass on the lessons I learned from my mistakes so others can make new ones. Hopefully really entertaining ones. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 9, 2022 Share Posted December 9, 2022 Well, dangy doodle. I like the look of that forge; are you saying it's a kit, or is it from scratch? Quote Link to comment Share on other sites More sharing options...
Max1775 Posted December 14, 2022 Author Share Posted December 14, 2022 Mikey, the forge is an Atlas. Had issues reaching welding temp so I built up the floor, created some door blocks with a smaller opening, then coated everything. Also replaced the stock burner with a good ol’ T-burner. It’s working quite well now. Quote Link to comment Share on other sites More sharing options...
