tokamak Posted November 29, 2022 Share Posted November 29, 2022 I have 240V single phase input source and a 240V 3 phase VFD. I want to know if the DPS phase shifter will work to convert the single phase power input from the wall to 3 phase power input for the VFD (which will then be used to control the 3 phase motor)? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 20, 2022 Share Posted December 20, 2022 What does the manufacturer say? Quote Link to comment Share on other sites More sharing options...
Latticino Posted December 20, 2022 Share Posted December 20, 2022 Some VFD will also accomplish the phase shift. I know the two I have plug directly into 240V single phase and have outputs to 3 phase electric motors. You should have a wiring diagram that details this. Quote Link to comment Share on other sites More sharing options...
Mike BR Posted December 31, 2022 Share Posted December 31, 2022 The VFDs I've looked at (not that many, I admit), take the input power directly through a diode bridge to rectify it into DC. If you connect use single phase input power rather than three-phase, four of the six diodes will have to do all of the work, and the rectified output will be "lumpier" than rectified three-phase. But it might work even if the VFD isn't rated for single-phase input, particularly if you don't run it at full load. Of course, you also might damage the VFD (but three-phase power can drop a leg and "single phase" so hopefully the VFD either can take it, or has a circuit to shut itself down on single phase input.) Quote Link to comment Share on other sites More sharing options...
Purple Bullet Posted December 31, 2022 Share Posted December 31, 2022 I tried a DPS on a donated surface grinder. Smoked it. The problem (I think) was that it was trying to run a three phase motor AND being transformed back to single phase for the oiling system and the magnetic chuck. Solution? I got a VFD for the grinder motor and ran separate circuits for the single phase stuff. Quote Link to comment Share on other sites More sharing options...
