Graham Fredeen Posted August 28, 2008 Share Posted August 28, 2008 Hey folks, I am really starting to consider getting a little 110/115v MIG. My little HF piece of xxxx buzz box is just not working out too well for me, so I think its time for an upgrade. In the past I have used a little hobart 115v MIG that worked very well, and would run up to about 1/4" thick material. I don't have 220v power in the shop, or I would just go with a nice big millermatic 210 or something of the sort. Plus, it is really handy to have a smaller welder that you can throw in the back of the truck and take places that don't necessarily have 220v access. Someday when the shop gets upgraded I will beef up the power and get some better welding equipment, but thats a long ways off and definately need something in the interim. So I was hoping some of you who have used a number of these little 115v MIGs could steer me towards a good one. Something that performs well (though I am completly aware of 115v limitations), and holds up well. And to clarify, I am after MIG w/shielding gas, not a sole flux core. Like I mentioned, my only experience was with a little Hobart, think it was the 140 model, and it seemed to work pretty darn good for running off 115v. But I wonder if there are better little MIGs out there. Any help is greatly appreciated. Graham Quote Link to comment Share on other sites More sharing options...
maddog Posted August 28, 2008 Share Posted August 28, 2008 I had the Hobart 115v MIG/Wirefeed welder and it was a champ. I think its the best kind of welder available for 115v. Miller makes almost exactly the same welder with different colors. I havent tried the Lincoln equivalent but I am sure its good too. This kind of rig is a lot more complicated than a buzz box and I would not go cheap. Definitely go with one of the quality names. Stick really works best with larger currents and larger inductances. The low currents and choppy power you get from 115v make it hard to stabilize the arc. I would have liked to have kept mine since its so handy for small stuff and runs off a regular wall outlet but I have a big IdealArc stick welder and oxy acet. so it was hard to justify the space and the money it tied up. Quote Link to comment Share on other sites More sharing options...
Jose Gomez Posted August 28, 2008 Share Posted August 28, 2008 Miller 140Millermatic 140 MIG Welder (115 Volt) Lincolin 140Power Mig 140C: Lincoln Mig Welders - Light Duty, K2471-1 Hobart 140WeldingDepot -- Hobart Handler Quote Link to comment Share on other sites More sharing options...
Mike BR Posted August 29, 2008 Share Posted August 29, 2008 I have a Lincoln 100 amp. It's held up well, but the I don't use it much. I keep it set up for MIG (.023 wire) and I just doesn't have the power for anything over thin sheet -- 14ga is pushing it. (That's okay, because I can stick weld anything thicker). I've seen some pretty impressive welds on thicker stock made with a Millermatic 135 (predecessor to the 140). So it's probably worth the extra expense for one of the 140 amp units Jose listed. Quote Link to comment Share on other sites More sharing options...
mike-hr Posted August 29, 2008 Share Posted August 29, 2008 I bought a new lincoln SP-125 plus, probably 8-10 years ago, for packing upstairs on the back deck to do final installations on railings. The little guy does okay in the shop, but I quickly noticed that electricians just can't see the merit in running a #12 wire with a 20 amp breaker upstairs to the back deck of any house. The little lincoln really doesn't like 15 amp breakers and #14 wire supply. I bought a Miller Bobcat portable with a Miller suitcase Mig set-up for it. The suitcase is real nice, even with the inconvienience of running cables from the Bobcat. I haven't used the little lincoln in over 5 years, I reckon I should take it to the next hammer-in and sell it for gas money. Quote Link to comment Share on other sites More sharing options...
Graham Fredeen Posted August 29, 2008 Author Share Posted August 29, 2008 Thanks for the info guys. I have some more to consider now. I used to work as a welder doing ornamental work, rails, stairs, fences, etc, and any other fab jobs that came in. We used the 220v Millermatics in the shop and they were always good. We also had the Miller bobcats on the trucks for the field, and I think there were a couple of suitcases for them, but we primarily stick welded our field welds. This little MIG would be mostly for my own shop usage, and the occasional odd job or need that might need to be welded elsewhere. I am pretty set on 140 amp for a little MIG and wouldnt want to go to a lower amp model. I do want to be able to do a decent bit of fab work with it and not just be limited to thin sheet. 1/4" would be decent enough for my uses. I guess my main concern was whether or not the Hobart held up as well to the competition. I have heard that Hobart is more of a "hobby" grade welder. In addition, there are the various biases that one welding manufacturer is better than the other, etc. And wanted to get some of your opinions on what you all think is best. It seems like the hobart can be a bit less expensive than the Miller and Lincoln models, and wondered if there was any reason to spend a hundred or two extra for lincoln or Miller. Quote Link to comment Share on other sites More sharing options...
KevinD Posted August 29, 2008 Share Posted August 29, 2008 Looks like I need to save up $350 more dollars... Mike HR - What'll you take for the little Lincoln? Quote Link to comment Share on other sites More sharing options...
Dave M Posted August 29, 2008 Share Posted August 29, 2008 If you look at the Hobart & Miller 140 amp Mig units they look all most the same. The sales man at the shop I buy my gases at said that they are made in the same factory. If you look at the miller on the wire feed and the amp control they are variable. On the Hobart unit they are preset on the controls so you can't slide in between whats on the dial. I have the miller unit and have had no problems and I use this unit all of the time because of its portability. I think if you are going to use it a lot I would go with the miller or the lincoln 140 unit. The shop that I bought my welder at sells all 3 units and I noticed the Hobart unit felt much lighter when I lifted it. Quote Link to comment Share on other sites More sharing options...
Johnnie C. Posted August 29, 2008 Share Posted August 29, 2008 I run a Lincoln 140 C and it works great. Its the most powerful 110 mig that Lincoln makes. I have welded up to 3/8in steel with no problems. I mostly us 75% Argon and 25% CO2 shielding gas. I prefer to use shielding gas over flux core. Gas is a lot cleaner than flux core. Quote Link to comment Share on other sites More sharing options...
Mike BR Posted August 30, 2008 Share Posted August 30, 2008 You could also look at the Millermatic Passport. It'll give you 140 amps at a slightly better duty cycle than the Millermatic 140. Or you can connect it to 220 and get 180 amps. Of course, it lists for $2000. Quote Link to comment Share on other sites More sharing options...
civilwarblacksmith Posted August 30, 2008 Share Posted August 30, 2008 I've been using a weldpak 100 from lincoln that is a 110/115 using 20 amp breaker. They have upgraded this unit to the lincoln 140. It will run both flux core or gas shield by reversing polarity. I run the flux core, just because of the convience of it. Most of what I weld is 1/4" but have welded thicker with multiple beads. Quote Link to comment Share on other sites More sharing options...
driberif85 Posted August 30, 2008 Share Posted August 30, 2008 Go with the Lincoln with infinite adjustments. I have used and abused these little 110 Lincoln welders and they never cease to amaze me with their abilities. Remember that what they are rated for is single pass weld. If you want to do multi pass welds you can weld thicker material. I recommend the Lincoln because in my opinion the have a smother arc and therefore less weld splatter. Quote Link to comment Share on other sites More sharing options...
Graham Fredeen Posted September 1, 2008 Author Share Posted September 1, 2008 Thanks for that info Dave, thats exactly what I wanted to know. I knew that Hobart was being built by Miller, and that some of their units are the same, but what you stated confirms my reservations toward the little Hobart. The Hobarts are a bit cheaper, but that is usually for a reason. I don't want to have to spend $600-$700 on a new Lincoln or Miller, but would rather spend more for a machine that will hold up better and perform better. There is no rush to get the welder immediately, so I am going to keep my eyes open for a used Lincoln or Miller that might be had at a better price. And thanks to everyone for you inputs, definately helped the decision making easier. Graham Quote Link to comment Share on other sites More sharing options...
nfinch86 Posted September 18, 2008 Share Posted September 18, 2008 Yes Lincoln is the Best in my opinion.I own the 140-T Great Machine! PS. I've been Welding 40+Yrs. & allways used Lincoln Machines . Norm : Quote Link to comment Share on other sites More sharing options...
ChrisB Posted September 18, 2008 Share Posted September 18, 2008 (edited) The 110v Lincolns are made in Italy. The Hobart and Millers are made in the US. I bought a hobart about 4 mos ago and had a setup question within 30 seconds of me dialing their number I was speaking to real person and had my answer 30 seconds after that. Hobart has an excellent forum that is watched by the factory. You can find it on the front page of the hobart website. Support after the purchase is a big thing to consider. Stop in the local welding shop and figure whose repair parts they stock. I'm in Miller/Hobart land here buying a Lincoln would mean a 3hr round trip if something broke vs. 5 miles to the local weld shop that stocks Miller and Hobart common failure parts. Esab makes a nice unit too. They are assembled in South Carolina. I dont know if they make a 110 unit. I would think hard about getting your shop wired for 220v. Edited September 18, 2008 by ChrisB typo fix Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted September 19, 2008 Share Posted September 19, 2008 Latest thing out there is from northern tool. 115volt Tig Mig and Stick all in one. 140 amp priced at $499.00 Quote Link to comment Share on other sites More sharing options...
KYBOY Posted October 1, 2008 Share Posted October 1, 2008 I have a Lincoln 140 at home..The reason I bought it was because I have put several hundred hours on one at the prison working outside(fences etc..). They are a real little welder and will weld good size material if you know what you are doing..I use .30 flux core most of the time as it burns very hot and I use it outside a lot..Miller makes a good small welder too.. Quote Link to comment Share on other sites More sharing options...
burd Posted October 1, 2008 Share Posted October 1, 2008 hobart 187 for mig and the Miller Dynasty 200 DX for stick and tig for me Quote Link to comment Share on other sites More sharing options...
